I am using a CS6 trial on Windows 7, I can get more specs later but I can't remember anything else about my operating system (on a different computer at the moment).
I have noticed sometimes that when using a Levels adjustment layer, the drop-down to choose the different channels (red, green, blue) is grayed out, and I cannot click on it to choose the different colors. The numbers in the input & output boxes are also grayed out and I cannot type in them.
The only time I have noticed this happening is directly after cropping an image. And then when I go to work on a different image and add an levels adjustment layer to it, those things are still grayed out. I have to restart the program to get it to work properly again.
If I add a Curves layer, nothing is grayed out, everything works fine; it's just Levels.
I am completely frustrated by this, and there seems to be no good reason for it and I haven't seen anyone else with this problem. I'll post screenshots later if it would help.
A screenshot might help, as I tried adding a Levels adjustment layer to several different images just now and am unable to reproduce the problem. In every case, I am able to select the color channels.
The question is whether it's a bug that's happening on your particular system, or whether you've done something inadvertent that makes adjustment of the color channels impossible. I can't think of what that might be.
-Noel
Okay, at first everything's fine. I add a Levels adjustment layer to my image. I can choose from the drop-down lists, nothing's grayed out. I then activate the crop tool, hit enter a couple of times to apply the crop, and now this is what the properties panel shows:
I can drag the sliders around, but can't choose from the drop-down list, etc.
I'm on a Dell Vostro, Windows 7, intel core i5-2450M CPU @ 2.50 GHz, 4GB RAM, 64-Bit OS. This is the second machine that I've tried this and still had the same problem on.
So... the CS6 trial was independantly downloaded from Adobe site on two separate machines. With seperate specs?
I've tried different ways to reproduce (Mac). And Noel can't reproduce either on PC.
huh.
Smarter people than me will have to help you.
Good luck.
edit:
You have your workspace set to Motion. Any change if set to Esentials?
Okay, I'm seeing something else. When I perform the crop, the adjustment layer was the active layer. This creates a problem. If the Background layer is the active, selected layer, and then I perform the crop-- the Levels layer will be fine!
So okay, I can work around it- but it still doesn't really make sense.
I can reproduce your results, but only by doing something that is counter-intuitive.
1. Open image
2. Create Levels adjustment layer
3. With Levels adjustment layer still active, select Crop tool
4. Press return - then I get the Background thumbnail and the preview shown in your middle screenshot
5. Press return to commit crop
6. The levels adjustment layer has the characteristic you describe - the drop-downs are greyed out. If I open a new image and add a levels adjustment layer, the drop-downs are stilled greyed out.
I say this is counter-intuitive, because of step 3. Normally, I would crop an image before adding an adjustment layer. And even if I did add the adjustment layer first, I would not leave it selected before cropping. It is the background layer I want to crop, so I would select that before activating the crop tool. For these reasons, this strange behavior is not a problem for me. I would never run into this problem with my normal workflow.
Thanks, I did figure that much out. But I still say the behavior doesn't make sense.
And to each their own; I like to crop the image last sometimes.
Also I don't think of it as cropping 'the background layer' or any other layer, but the whole entire image, so in my mind it didn't matter which layer was selected. Except now I realize that it does because of the way it's programmed.
I can also confirm the issue (PC, CS6).
Workflow aside, this behavior is not what one would expect nor is it the way previous version worked. Once the levels behavior is messed up it is persistent and any other image which had a levels layer is also affected. You can return the levels layer back to normal by double clicking on the levels layer (not the icon, not the name), which brings up the Layer Style dialog. Ok or cancle out of that and things are back to normal.
Seems like a genuine bug to me.
Paulo
I saw too late that you had already figured out that it was the selection of the adjustment layer before cropping that was causing the problem. Regarding the order of cropping: I try to do my cropping first because I don't want parts of the image that I will be cropping away anyway to influence the adjustments I apply to the core image.
Even though I can't reproduce, i agree with Paulo that it reads like a bug to me too. It should not matter what Layer is targeted when you commit a crop.
Jenna, you should go here: http://feedback.photoshop.com/
and file it. Describe your steps to reproduce and what happens as opposed to what you expect to happen.
