alexthebake
How do I Select all the items in a document based on SpotColor?
Jun 28, 2012 1:46 PM
Tags: #illustrator #color #javascript #selection #scripting #illustrator_cs5 #selection_color
I'm trying to select every object with the color "CutContour"
So far I've been trying:
myDoc.selection = myDoc.spots.getByName("CutContour");
I guess this obviouslly wouldn't work though because myDoc.selection is looking for an array of objects.
However, I can't figure out how to loop through all the objects in the document and check to see if they contain the SpotColor.
Any help would be incredibly appreciated!
EDIT:
I want to use the Select > Same > Stroke Color , but I heard that using that in Javascript isn't available unless you have CS6 (which I currently don't). Is it true that accessing menu items through scripting is a feature in CS6?
    Jun 28, 2012 2:10 PM   in reply to alexthebake
    Yes you can't do this as straight forward as you hoped… In script probably the same as is done in those app/plug-in's you will need to loop through all the art items and test each in turn… Depending upon your art in question this can become a very complex routine… Why are you trying to select this stuff?
    doc.selection = [ wants an array of objects ]
    myDoc.spots.getByName("CutContour") is only going to find an object reference to a spot swatch in the document swatches panel if it exists…
    You can't put these together like you have done…
    To your edit Yes its a new thing with CS6… I don't have this either… boo
    Jun 28, 2012 2:54 PM   in reply to alexthebake
    pageItems is a super class like swatches It covers a few common/shared properties but under each are sub-classes that contain more specific properties…
    getting pageItems will return an array but it could be mix of [ pathItem, textItem, groupItem etc. ]
    getting swatches could return [ spot, rgb, cmyk, gradient etc. ]
    If you are wanting to access only pathItems then access that collection at what ever object level you want to deal with… e.g.
    var a = doc.pathItems;
    You can check the collections length property and create a loop…
    For each item you can test the pathItem for it's .fillcolor & .strokecolor properties
    Jun 29, 2012 1:32 PM   in reply to alexthebake
    Wow you use the CutCountour for Roland printer?  is it 100% cyan?
    Ok I had a similar need and I figured out:
    if(objects[i].fillColor.typename == "SpotColor"){
         if(objects[i].fillColor.spot.name =="CutContour"){
              //process the objects[i]
