copy clip with start time?
Jun 28, 2012 11:04 PM
Tags: #paste #copy #clipstarttime
how would one copy a clip from one sequence to another and keep  its start time intact?
Thx
    Jun 29, 2012 7:10 AM   in reply to skavan23
    I don't understand the question.  The Copy process doesn't change anything.
    Jun 29, 2012 2:23 PM   in reply to skavan23
    Select it in the timeline, CTRL-C (copy) , Next sequence....Ctrl-V (paste) at the playhead position .
    Jun 29, 2012 2:47 PM   in reply to skavan23
    Select multiple clips from first sequence and copy them in one action, then paste them as one action into new sequence (ie. multiple clip copy and paste)
    That way you only need to park the playhead once
    Jun 29, 2012 4:04 PM   in reply to skavan23
    I know I could move the playhead to that position in the new sequence and then paste
    That is the only way to paste anything in exactly the same relative spot in any application, not just PP.  You put the 'cursor' where you want the paste to go.
    Jun 29, 2012 9:41 PM   in reply to skavan23
    Graphics programs are spacial based (x, y, z) and editing applications are time based .(temporal)
    You want a solution  to a time issue for what you asked and thats not possible (currently) - make a feature request..
    ...so that leaves you with my original "solution" or maybe ...
    duplicate the sequence and then delete what you dont want.
    Jun 29, 2012 10:56 PM   in reply to skavan23
    You can just make one good sequence and then import that sequence into the other sequences (if that makes sense). You don't have to change the playhead position in this case and can just paste at time 0. Then you can copy this and paste it into other sequences faster.
    This will also build layers of sequences in your project and might help you in the future (like if you make changes later and want them to apply to all sequences). Its like building "Pre-compositions" in AE.
    Jun 29, 2012 10:59 PM   in reply to pheng@applevideo.us
    He / she  would then still have to delete what he did not want ( just as I suggested previously).
    Duplicating a sequence is far faster than importing one also.
    Jun 29, 2012 11:16 PM   in reply to shooternz
    Yeah. Meant duplicate or simply dropping the sequence down inside another. Have fun Skavan.
    Jun 29, 2012 11:52 PM   in reply to pheng@applevideo.us
    A nested sequence  wont work without extra effort.
    Jun 30, 2012 9:40 AM   in reply to shooternz
    You could put 5 sec of bars at sequence time zero, and select this clip and the one you want. Then you could paste into the new sequence at zero and delete the bars when you have finished.
    Richard Knight
    Jul 1, 2012 10:25 PM   in reply to skavan23
    Shift-Click> Ctrl-C> Ctrl-V.....Bingo
