Folder Hierarchy on android project
Jun 29, 2012 12:51 PM
Tags: #android #folder #hierarchy #folder_hierarchy
Hey guys!
So, I'm having a issue here that I hope someone may help.
My project folders are organized like this
assets
     sub_folder
          somevideo.flv
bin
     sub_folder
          myproject.swf
src
     sub_folder
          myclass.as
I want to play somevideo.flv using NetStream. I included the assets folder in the publish settings for android 3.2 (the added path is the full path not only the relative path so I got something like "c:\users\myname\documents\....\assets"
suppose my NetSctream object is called stream. What should the string value of path be set to? I was thinking something like "../../assets/sub_folder/somevideo.flv" but can't get it to work.
this.stream.play(path);
    Jun 29, 2012 2:38 PM   in reply to marcelbatista
    The path where you read the files included as part of the structure of the application, use an absolute path does not make sense.
    You should create a folder for the videos is part of the structure based on your app.
    Maybe, you could find the file without path, ie path = "somevideo.flv"
    Jul 2, 2012 9:25 AM   in reply to marcelbatista
    where say 'included files' you can only add file to package in the apk file, you can't add paths, you only can add files
