spry tabbed panels
Spry tabbed panles default hide
Apr 24, 2012 8:56 AM
Tags: #tabbed_panels
Hello,
Im with some problems with the spry content tab. What I need is to:
as default hide the content of the spry tabbed panels and also hide on mouse out
please advise if you needto check my codes and site
thanks
    Jun 29, 2012 5:07 PM   in reply to spry tabbed panels
    I see that time has passed and you have not gotten a response to your question.
    What exactly is to be hidden when the mouse is not hovering; what is to be showing when the mouse IS hovering?
    It is possible that the solution will not be to use Spry Tabbed Panels, which would require a lot of adapting.
    For a simple solution, if you don't mind the "contents" to be lined up next to each other, float divs next to each other. Set a height that encompasses your title but make the overflow: hidden. Add a css style that makes overflow: visible;
    Here is some simple code for that:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml">
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <title>Untitled Document</title>
    <style type="text/css">
    .change {
              float: left;
              height: 2.5em;
              width: 100px;
              overflow: hidden;
    .change:hover {
              overflow: visible;
    </style>
    </head>
    <body><div class="change"><h3>Title</h3>
    <p>Here is a basic element</p></div>
    <p>Here is a basic element</p></div></body>
    </html>
    I fiddled around a bit with the tabbed panels, but couldn't find an easy way to make them appear and disappear on hover.
    Your other possibility is to do disjoint rollovers using the Show-Hide behavior, but it seems difficult to have the "content" start out invisible.
    I hope you have solved the problem by now, or that these suggestions give you some ideas.
    Beth
