omar_m
Need help selecting and changing colours
Jun 28, 2012 8:34 AM
I have been given the following graphic: http://i.imgur.com/iUVfn.png
I have it in an Adobe Illustrator file format
I've never used the program before!
I need to change the red into white and the white into red
How do I do this?
I've opened up in illustrator and can't seem to select on specific part
When I try to sellect, it selects everything
The client has asked me to do the work - since the original graphics designer wants to charge a fortune for the changes
I'm guessing it's a 1 minute job
Any help would be greatly appreciated
Omar
    Jun 28, 2012 8:59 AM   in reply to omar_m
    If it's a vector graphic in Ilustrator format, and not just a graphic embedded in Illustator, then this will work:
    Choose the graphic and then in the color pallet: add selected colors.
    Create a third color as a placeholder for the white.
    Draw a box and make the fill and stroke the white color that was added to your pallet.
    In turn,
    Select>same>stroke color and change to your placeholder color
    Select>same>Fill color and change to your placeholder color
    then follow the same procedure to change the red to white, and the placeholder color to red.
    Jun 29, 2012 9:04 AM   in reply to omar_m
    Hi there - Do you know if this original file is a vector image? The file you linked to is a rasterized .png file. If the original is a .png raster image, you can easily alter the colors in Photoshop.
    Jun 29, 2012 8:43 PM   in reply to omar_m
    This might work for you if the art is either outline text or live text.
    http://www.wadezimmerman.com/videos/EditColorII.mov
