I keep on experiencing red screen glitches in my videos while viewing after render and when exported into any format. After replacing the clip with another, the same problem appears at the exact same time as before. The only way to get rid of the glitch is to build a completely new project. I have attached a picture of the glitch (the JPEG is green for some reason).
Any solutions?
My best GUESS is that your project sequence does not match your video
So, read/reply - http://forums.adobe.com/message/4200840
Thank you for the suggestion but I am pretty sure that is not it. All of my clips are recorded in AVCHD and the sequence has the same settings as the source file. Also, CS6 will automatically match the sequence to the source files.
The glitch only occurs with some clips which cause red screen glitches and abnormal render times. I will do more research and play with Premiere some more. Will post a solution if I can find one. ![]()
