Expand/Contract Area
Mar 16, 2012 12:45 PM
I have a button the has the plus symbol
When clicking the symbol I want to show a box (in the same area) with a an x in the same place as the and have the X reveal the
Here is an example:
How should I go about doing this?
Do I make a multi state object where the 1st state is the plus and the second state is the X with the text. (But then the whole thing would be able to be closed clicking anywhere)
    Jun 30, 2012 2:10 AM   in reply to blasto333
    And how did you do that? Can you please share a direction here, it would be helpful, thank you!
    Jun 30, 2012 4:49 AM   in reply to 3rd Element
    Step 1: Create the 2 display mode (the "+" and the "x"ed info). Make sure to group each mode if it's made from several items.
    Step 2: Place the items (groups) on top of each other, aligning the "+" and "x" to the same position, select both and use the Object States panel to create a multi-state object. Change the default name given to the MSO so you'll be able to recognize it later.
    Step 3: Draw an empty shape/frame around the tapping hot zone, convert it to button and using the Buttons panel set the button action to Go To Next State, and make sure to select the correct MSO name.
    Now you have a multi-state object that changes to the next state each time you tap on the button.
    Jun 30, 2012 5:47 AM   in reply to Adi Ravid
    I'll try, thank you Adi!
