Mercury playback engine makes Premiere crash after cs6 update
Jun 30, 2012 2:16 AM
Tags: #nvidia #mercury #premiere #playback #crash #cs6 #engine #quadro
Hi there everyone,
I have been working with Premiere cs5 for over a year without any serious errors. Since I upgraded the entire Creative Suite to cs6 however, I am forced to use the software playback method instead of the GPU accelerated one. Using the last mentioned causes Premiere to crash immediately when trying to drag any sort of video on the timeline. This happens in new projects as well as in cs5 ones; and all of the footage involved in both cases was ingested in the wellknown Matrox i-frame codec that always worked fine before. Specs:
Windows 7, 24 gB RAM (not sure whether DDR3 or 5), NVidia Quadro 4000, dual six-core CPU, several terras of HD @ 7200 rpm, Matrox MX02 LE, CS6.
I tried every possible combination and order of uninstalling an reinstalling Premiere, the Matrox drivers and the nVidia drivers, including older versions of the last two mentioned, but to no avail. Though it looks like an NVidia issue (I read somewhere about CS5 and 5.5 certified NVidia drivers but not CS6 yet) this problem manifested right after the upgrade to CS6.
The error reported is about the graphics card being reset, it stops and then recovers, leaving Premiere to hang. The card's hardware reacts with a noisy cooling fan acceleration sound that slowly falls back to its normal rpm.
-Sigh- I am sorry to bother you with this, but does anyone have any idea or experienced something similar? Does the combination of the mentioned elements ring a bell...?
Any help is utterly appreciated !
    Jun 30, 2012 3:01 AM   in reply to Lewiz
    Do you have the latest nVidia drivers installed? Can you replicate this problem when you completely leave out the Matrox from the equation?
    Jun 30, 2012 6:00 AM   in reply to Lewiz
    You could try to roll back one or two versions of the nVidia driver from the nVidia website. Otherwise I have no suggestions at the moment.
    Jul 1, 2012 1:14 AM   in reply to Lewiz
    When a system reboots on its own volition, without user action, that is mostly an indicator of hardware problems. Can you find any relevant info in the Event Viewer? What are the temps of CPU, GPU and mobo just before this happens? What are the voltages on the various rails?
    Jul 1, 2012 9:18 AM   in reply to Lewiz
    Your original message said you did an upgrade.  Did you remove CS5 prior to installing CS6 or did you just do an upgrade?  If you did an upgrade, I would uninstall CS6, go to the Adobe folder in your Windows directory and delete it completely.  Make sure your preferences file gets deleted if it is located in the Users directory.  I'm not sure where the default location is but delete it.
    Reboot your machine then do a clean install with CS6.   I have the Nvidia GeForce GTX 570 in my PC and the Mercury playback engine works just fine.  Have you tried removing the Matrox from your system?  I would also try that and see if your system sees the Nvidia without the Matrox in it.
    I have had problems with Nvidia and Premiere in the past and a completely clean install worked for me.
    Jul 1, 2012 9:29 AM   in reply to Gary Agoura
    I would after uninstall runt the Adoe removal toll, to get all hidden settings etc. Out
    http://www.adobe.com/support/contact/cscleanertool.html
    Ulf
    Jul 2, 2012 3:42 AM   in reply to Lewiz
    Good that at least CS5 works, but I would suggest you file a bug report for this issue and also provide a link to this thread. I guess that the problem is the nVidia driver and not so much Adobe, otherwise if would almost certainly have been noticed in the beta stage.
    Jul 2, 2012 8:07 AM   in reply to Lewiz
    Click on Show Details on the Announcement at the top of the page or go here: http://www.adobe.com/go/wish
    Dec 21, 2012 11:56 AM   in reply to Lewiz
    Tom,
    One thought on the intermittent nature of the Quadro 4000 issues could be heat - too little (soldered joint shrinking), or too much (some component becomes overheated).
    It could also be that a component fails, under a particular load. I have seen similar with bad RAM, where most programs would not stress all of the sticks, and then a program, like PrPro, or PS would use all of the RAM, and the user would see a failure, usually in the form of a BSOD.
    The great news is that your new Quadro 4000 is working fine, and you might never know what the root cause was.
    Good luck,
    Hunt
    Apr 9, 2013 5:57 AM   in reply to Lewiz
    Same probleem came out of the blue. The moment mercury was active adobe crashed. New drivers did not fix it. Then found this and it worked (Just today though so lets see)
