Content aware fill - how to sample from small area?
Jun 30, 2012 8:16 AM
Is there a way how to sample from small area and then apply content aware fill to the much more bigger area? For example - there is an object on a table. The object fills 90% of the image and the table 10% image. Now, I just want to delete the object. But that doesnt work with content aware fill, because the area around it is much smaller. Is there a solution for this?
    Jun 30, 2012 8:18 AM   in reply to hellboy801
    Well, straight answer: It's bound to fail not only for technical reasons. Any cloning will be obvious beyond anything acceptable. find additional imagery, clone across different images/ using different layers - the old fashioned way.
    Mylenium
  • Trevor.Dennis
    May 24, 2010
    Jun 30, 2012 3:06 PM   in reply to hellboy801
    I am not sure that CAF is the right tool if you want to fill a large area sampling from a small area.  You might get away with doing it in stages
    One trick is copy just those areas you want to sample from, to a new layer, and use CAF on that layer, but without seeing your image, it is difficult to say what the best aproach is going to be.
  • Noel Carboni
    Dec 23, 2006
    Jun 30, 2012 5:56 PM   in reply to hellboy801
    There is a Russell Brown tutorial on Adobe TV that tells you how to do just what you're asking via masking.  Unfortunately I don't have a link but look for a tutorial where he Replaces a curved window in a brick wall.
    -Noel
  • PECourtejoie
    Jan 11, 2006
    Jul 2, 2012 7:51 AM   in reply to Noel Carboni
    Hello!
    Yes, you need to mask the non-table area, and select the area you want to sample from: see this video that Noel referred to: http://tv.adobe.com/watch/the-russell-brown-show/masking-magic/
  • Noel Carboni
    Dec 23, 2006
    Jul 2, 2012 10:02 AM   in reply to PECourtejoie
    Thank you, Pierre - yes, that's the video I was thinking of.
    -Noel
