sprintgranit
64bit compatibility
Jun 30, 2012 3:10 AM
Hi there, will photoshop 5.0 run on a 64 bit system?
    Jun 30, 2012 7:33 AM   in reply to sprintgranit
    Yes. It ships with both 32 and 64 bit, and you can use whichever you want at different times. Some plugins don't work for 64 bit so you might need to swap between the two. I think Bridge is only 64 bit in CS6 (and it's very fast!)
    Jun 30, 2012 8:09 AM   in reply to rob_ashcroft
    Perhaps you are jumping to the wrong conclusions... If he means the original PS 5.0 from the last century and not CS 5 then the answer clearly is no.
    Mylenium
    Jun 30, 2012 9:07 AM   in reply to Mylenium
    Mylenium
    Oops! You might be right. I get so used to just using CS
  • Noel Carboni
    Dec 23, 2006
    Jun 30, 2012 10:01 AM   in reply to sprintgranit
    Actually, since pretty much any 32 bit application should still be able to run on a Windows 64 bit system, Photoshop 5.0 may well run.  But it may not even install properly on a modern system because of permissions issues, disk size issues, etc.  That said, I can run Photoshop 6.0 on my Windows 7 x64 system no problem.  I've just not tried 5.0.
    There is of course the possibility of running it in Virtual XP.
    -Noel
