I can only spell check in English and I work in various languages. I went to File > Properties > Advanced > Reading, changed it to Spanish
Then Edit > Check Spelling > In Fields editable text, comments then when it opens it does not show Editable Text.
How do I set my text to Editable Text. I have searched and have not found the solution. There are documents that I have created myself. Thanks for the help ...
Figured out the solution: Go to Edit > Preferences > Spelling > Check the languages you wish to use and move them up to the top. Make sure the language you wish to use in a particular document is at the very top since it seems the Adobe is not intuitive. . I guess it will not check multiple language in the same pdf document.
Is this for the Adobe Acrobat program?
I asked because if it is, this post needs to be moved to that forum. This forum is for discussing Adobe Captivate and that's an equine of an entirely different hue!
Cheers... Rick
