sukhwinderp
Scanning Epson V300 Into PhotoShop CS6 Mac
Jun 30, 2012 3:52 PM
I just bought CS6 for Mac for a mere $1400 CDN, using a brand new mid-2011 iMac. I have an Epson V300 Photo Scanner. If I install the Epson Scanner Driver and EPSON Scan Utility v3.51 from Epson's website (says it's compatible with Mac OS X 10.7 and even 10.8 - see link below), will I be able to use the File >> Import function to scan directly into PhotoShop? With my old Epson Scanner, I have to use Apple Preview to do my scans.
I'm confused about all this TWAIN 64-bit stuff. Makes no sense to me. Just want to be able to put a document into my scanner and go to PhotoShop File >> Import and see my scanner like I was able to do in my old version of PhotoShop.
Epson V300 Driver Download
    Jun 30, 2012 4:30 PM   in reply to sukhwinderp
    You should be able to import from it via the ImageKit/ImageCapture drivers - but TWAIN is still risky (lots of bugs in the drivers), and mostly unsupported in 64 bit (I don't think Epson ships a 64 bit driver).
    You're probably best off scanning inthe stand alone application.
    Jun 30, 2012 5:10 PM   in reply to sukhwinderp
    They should be installed when you install the scanner drivers.
    It should just show up, but I don't know every scanner model's specific drivers.
    Jul 5, 2012 5:26 PM   in reply to sukhwinderp
    Somewhere the scanner driver is still installed. It could be ImageKit, TWAIN, or a plugin specific to that scanner.
    You'll have to find and remove that driver.
    Feb 1, 2013 11:51 AM   in reply to Chris Cox
    Hello
    is this the only way to scan from Photoshop CS6 with Epson V300? There are very poor control, no advanced settings?
