sifishman
C++ Runtime error  PSE 9
Jun 21, 2012 2:15 PM
When I start PSE 9 organizer I get an error message: This application has requested the Runtime to terminate it in an unusual way...  I reinstalled PSE 9 but got the same message.
  • 99jon
    Jan 6, 2010
    Jun 22, 2012 2:30 AM   in reply to sifishman
    This is usually a Windows system fault and the error log is the first place to look.
    Start Button à Control Panel à Administrative Tools à Event Viewer.
    In the left panel highlight Application (under Windows Logs) and look for errors logs with the red exclamation mark.
    If you see anything relating to Adobe copy and paste the information from the details tab.
    These errors can be caused by a variety of faults e.g. a corrupt dll file. The log should help to pinpoint the problem.
    Click to view
    Jun 23, 2012 12:27 PM   in reply to sifishman
    Look for the new entries having the red icon and that refer to Photoshop Elements.  Copy the error text into a message here.
    Ken
    Jun 23, 2012 7:19 PM   in reply to photodrawken
    I find it interesting that I suddenly started getting the same runtime error when I try to open Elements 9 or Premeir on June 21. I went back though my events log and the error message is
    Event Type:Error
    Event Source:Application Error
    Event Category:None
    Event ID:1000
    Date:6/21/2012
    Time:6:32:33 PM
    User:N/A
    Computer:LIBBYE
    Description:
    Faulting application photoshopelementseditor.exe, version 9.0.0.0, faulting module msvcr90.dll, version 9.0.30729.4148, fault address 0x0005bea4.
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
    Data:
    0000: 41 70 70 6c 69 63 61 74   Applicat
    0008: 69 6f 6e 20 46 61 69 6c   ion Fail
    0010: 75 72 65 20 20 70 68 6f   ure  pho
    0018: 74 6f 73 68 6f 70 65 6c   toshopel
    0020: 65 6d 65 6e 74 73 65 64   ementsed
    0028: 69 74 6f 72 2e 65 78 65   itor.exe
    0030: 20 39 2e 30 2e 30 2e 309.0.0.0
    0038: 20 69 6e 20 6d 73 76 63in msvc
    0040: 72 39 30 2e 64 6c 6c 20   r90.dll
    0048: 39 2e 30 2e 33 30 37 32   9.0.3072
    0050: 39 2e 34 31 34 38 20 61   9.4148 a
    0058: 74 20 6f 66 66 73 65 74   t offset
    0060: 20 30 30 30 35 62 65 610005bea
    0068: 34 0d 0a              4..
    I've tried a bunch of fixes for this annoying error but none of them work for long.
    Jun 23, 2012 7:39 PM   in reply to docterv
    Thanks for posting the info.  Have you tried these Adobe suggestions?  Even though this document is for the Creative Suite products, Solution #2 would be appropriate for PSE9, and should allow you to install the 9.0.3 update:
    http://helpx.adobe.com/creative-suite/kb/crash-launch-modname-updatern otifications-dll.html
    Ken
    Jun 23, 2012 8:40 PM   in reply to 99jon
    I'm new thanks for help. I'm mostly learning and here is a lot to learn.
    Jun 24, 2012 8:18 AM   in reply to photodrawken
    Thanks to Ken! I tried Solution #2 and the Editor opened without the error message. Yay!
    Jun 24, 2012 10:51 AM   in reply to sifishman
    Unless there's something in the Event log referring to Photoshop Elements, or Adobe, there's not a lot to suggest.
    Did it ever work without that error?  If so, what changes did you make to the system or in Organizer just before it started getting the error?
    Ken
    Jun 24, 2012 11:10 AM   in reply to sifishman
    At this point, you've got nothing to lose by trying.
    Ken
    Jun 29, 2012 6:30 AM   in reply to docterv
    Update-I started getting the Runtime error again. The fix we discussed worked again so I made a just made shortcut to the PDapp.exe file for my desk top.
    Jun 29, 2012 10:28 AM   in reply to docterv
    docterv,
    Hmmm...the patch should only need to be applied once.  There might be some corruption in your user account.  Try creating a new one and see if running under that account fixes things for good.
    Ken
    Jun 29, 2012 12:02 PM   in reply to photodrawken
    I've created a new account and will report back if I get the error message again. Thanks!
    Jun 29, 2012 1:33 PM   in reply to docterv
    Got my fingers crossed for you.
    Ken
    Jun 30, 2012 3:34 PM   in reply to photodrawken
    Fired up a new adobe account with a different email account and the error returned the next time I opened the Editor. It seems that the only way to get it to open without the error is to use the PDapp.exe file before attempting to open PS.
    Weird.
    Jun 30, 2012 9:16 PM   in reply to docterv
    I was referring to a new user account in Windows  -- that's where the corruption might be.  Sorry about the confusion.
    Added:
    I just realized that you should first log out of your Adobe account, then exit PSE, then use Task Manager to kill any running Adobe processes before applying the patch.
    Ken
    Message was edited by: photodrawken to add comment.
