I tryed to change my .JPG files to default to CS6, I go thru all the procedures but CS6 does not show up in my sysem default program list. The answer from Microsoft is the CS6 did not register in the system registry when I installed it. How do I accomplish this?
Ruben
I want to default association for .JPEG, .JPG files to CS6. CS6 will not
show up in the system default program list. I tried to go to properties of
a .JPG file then "browse" for a default, I select photoshop CS6 as my
default program, but, it does not accept. Microsoft tells me that when CS6
was installed (recently) it did not register properly in my systems
registry. How can I get CS6 registered into my system registry so it shows
up in the default program list???
Thanks for your help
Ruben
What do you mean by, it does not accept?
There are 2 ways to do this,
Ideally that should work. If it does not, tell us exactly whats happening when you try to do so.
You have too many file handlers. Clean them out using your Windows Explorers File --> Organize --> File Types and then manually re-associate them with Photoshop using the Open with... method. And make sure the file associations are not reinstated by any other programs liek virus scanners, image viewers, packer tools and so on...
Mylenium
Yes, I understand what you are saying and I have been following these
procedures for many years. I know very well how to associate a file type
with an application. I'm so sorry my question is not understood. According
to Microsoft when I installed CS6, it did not update my system registry
properly so it will not show up as a program in the associate file list. I
even went to browse and clicked on the CS6 Photoshop.exe file to associate
an open .JPG file. This failed.
I guess I probably should uninstall CS6 and re-install it to see if it
registers properly to Windows 7.
RBlindley
Microsoft people are correct ...it is the registry issue because of which the problem is coming up.
NOTE:- Please create a system restore point and do the registry Back up before making any changes , as playing with the registry could be fatal for your computer.
Navigate to Computer\HKEY_CLASSES_ROOT\Applications and find your .exe name ex:- Photoshop.exe
Navigate under its name to shell>open>command.
In the Default change its location to the actual location of the executable, Ex:- "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe" "%1" ( at my end)
hit okay and then try and reassociate the file type as you normally would.
