Replacing Disc Menus background image
Jun 11, 2012 8:05 AM
Tags: #elements_10 #background_image #disc_menu
Hi
My current project is set to PAL HD 1920 x 1080.
As a basis I have used the slideshow HD disc menu template.
On the main menu I have browsed for a still picture to replace the background and have selected an image sized to 1920 x 1080 pixels.
The new background appears but does NOT fill the frame (bars down left and right hand side). Looking at the image it appears that the image has been squashed horizontally (not as wide as it should be).  Elements does not allow me to expand the image.
I have tried creating both DVD and HD content, all menus have bars down the side.
Why??
    Jun 11, 2012 8:33 AM   in reply to BLZP
    This is because your photos are 4:3 and your video frame is 16:9.
    Try making a copy of whatever photo you plan to use as a background, then open it in Photoshop, size it to 1920x1400, then crop it (or change the Canvas Size) to 1920x1080. Should fit perfectly then.
    Jun 11, 2012 10:25 AM   in reply to BLZP
    I don't know. I've never experienced that. Sorry I can't help.
    Jun 29, 2012 6:13 AM   in reply to BLZP
    I can repeat the problem you have, using a custom 1920x1080 still image background in the HD P&Z menus. Interestingly the background images in the HD Pan and Zoom template are1440 x 1080 images:
    So when I compare the template image with the Disc Menu image it is obvious that the template distorts the background image by stretching the sides to fit the 1920 width. Whereas using my (and yours) custom 1920x1080 images it retains the aspect ratio - leaving the black borders.
    I rather think this is probably a fault in that particular HD template so I suggest you try some of the others and see if they do the same.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
    Jun 29, 2012 6:46 AM   in reply to BLZP
    I also tried a few more and they all exhibited undesirable behaviour:
    • Leaves the black bars.
    • Overlays, rather than replaces, the background.
    • Puts the custom background into the live action box if the template has one.
    The only other suggestion I have is the one you're doing - contacting Adobe direct.
    Good luck, and if you get a solution do please post it back here in this discussion.
    Cheers,
    Neale
    Jul 9, 2012 5:29 PM   in reply to BLZP
    I see the behavior you are talking about here. Not sure of the exact cause just yet, be we'll look into it. For now, your method of opening the PSD file that is the basis for the menu and adding your image as the background should work just fine. Just make sure that you are not adding any layers and maintaining the layer names and structures. This means copying in your new image, which will be in its own layer, moving that layer to just above the "background" layer, and using Merge Down from the Layer menu (Command/Ctrl+E).
    Jul 13, 2012 10:08 AM   in reply to BLZP
    BLZP, I'm not sure what you hoped to accomplish by chatting with tech support last night. I have already replicated the issue and reported it directly to our engineering department for repair. Tech support isn't going to be able to provide a solution to this issue. Basically, at this point, we can only wait for engineering to fix this from the inside.
