Kmotion007
Error 6 & 7 with 3 Creative Cloud Products
Jun 19, 2012 7:48 PM
Tags: #error #after #effects #install #indesign #creative #fireworks #7 #trial #6 #download #cs6 #installation #cloud
I get Errors 6 and 7 with CS6 Creative Cloud installation attempts with After Effects, Fireworks and InDesign. I also tried to install the trial versions, as an Adobe Rep suggested in the forums, but they still did not install.
I have the proper Mac system requirements and have tried numerous other solutions given online. All to no avail.
HELP! Please.
    Jun 19, 2012 9:14 PM   in reply to Kmotion007
    We need more details like your OS and install logs.
    Jun 29, 2012 5:19 PM   in reply to Kmotion007
    As per the logs following fonts seems to have got corrupted -
    "/Library/Application Support/Adobe/PDFL/10.9/Fonts/AdobeFanHeitiStd-Bold.otf"
    Open Terminal application and run the following commands (as in thread) one by one. Enter password when prompted and hit return -
    sudo mv "/Library/Application Support/Adobe/PDFL/10.9/Fonts/AdobeFanHeitiStd-Bold.otf" /tmp/
    It would move the corrupted font files to temp.
    Now try running the installer again.
    Jul 1, 2012 2:32 AM   in reply to Kmotion007
    Ok , then navigate to /Library/Application Support/Adobe/PDFL/10.9/Fonts and move the content in the Fonts folder to the desktop and then check.
    Jul 1, 2012 5:59 PM   in reply to Kmotion007
    After moving them to the desktop as you directed and AE properly installed I opened up my old PDFL file again and saw that it had installed only a 10.9 sub-folder within it. I'm guessing the older version sub-folders were the culprits for the previous installation errors. Correct or not?
    Correct , there was something wrong , not sure what however.
    INDESIGN PARTIAL INSTALLATION - CAUSE FOR CONCERN?
    This is the install log from InDesign when I successfully installed the program after trashing the old PDF file as described above. Do I need to be concerned about this? What does it mean?
      DF024: Unable to preserve original file at "/Library/Application Support/Adobe/Linguistics/6.0/Providers/Proximity/11.00/swd58.ths" (Seq 409)
    It is the similar error as earlier , this time it is the Linguistics file ,
    First check you should have complete "Read and write" Permission to the "/Library/Application Support/Adobe/" folder and it's enclosed component.
    Secondly if incase this doesn't work then copy the 11.00 folder on desktop (do not trash ) and then check.
