After Effects Cs6 Installation Won't Work!
Jun 30, 2012 6:41 PM
Tags: #install #cs6
Im am trying to install after effects cs6 but it keeps stopping a 2% and has all these things to make it work, i do everything it says (ive done it about 7 times) and it Still won't work! someone please help!
Error Summary:
Exit Code: 34
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 0 error(s), 0 warning(s)    FATAL: Payload '{0A1E2FE2-B2AD-42F4-9C74-641853FB093A} Photoshop Camera Raw 7 6.0.98.0' information not found in Media_db.
    Jul 1, 2012 10:49 AM   in reply to Overthouqht
    Which operating system are you using?  I would recommend starting with utilizing the Adobe Support Advisor at http://www.adobe.com/support/loganalyzer/ to automatically review your installation logs.
    Alternately you are welcome to review your log files manually to determine what may be causing your difficulty.  You can find details on how to accomplish this at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html.
    Jul 2, 2012 12:24 PM   in reply to Overthouqht
    Yes it most certainly could cause difficulties with future installations.  Which operating system are you using?  Please follow the directions listed in CS Cleaner Tool for installation problems | CCM, CS6, CS5.5, CS5, CS4, CS3 - http://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation -problems.html.  This will allow you to utilize the normal uninstall process followed by using the Cleaner tool to remove any additional software.  Feel free to respond to this thread if you have any questions about the steps listed within the document.
    Jul 11, 2012 9:44 AM   in reply to Overthouqht
    In what way will it not go away?  Are you still able to see After Effects CS6 in Start>All Programs?
    Also to help determine which OS you are using you can go to Start>Computer and select Properties.  This should allow you to determine the exact OS you are using.
    Jul 13, 2012 10:35 AM   in reply to Overthouqht
    Do you receive an error message when you try to remove the software using the Programs and Features Control Panel or when utilizing the Cleaner tool?
    Jul 14, 2012 12:17 PM   in reply to Overthouqht
    Did you try the steps listed in message #2 to review your installation log?  Either the Adobe Support Advisor or a manual review of the install log may help identify what is causing your difficulties.
    Jul 15, 2012 10:49 AM   in reply to Overthouqht
    The instructions on how to review the installation log are in message #2.  If you are viewing this view e-mail then you either will want to click the link titled View the Full Discusssion or click on http://forums.adobe.com/message/4558393#4558393 to view the thread in your default web browser.
