Why Does Flash (SWF) Get Corrupted When Imported?
Jul 1, 2012 4:57 AM
Hello,
Specs...
Windows 7
10 Gigs Ram
Quad Core AMD Chip
The biggest reason I joined the cloud was to use Premiere Pro so that I could import SWF files.
In Premeire Elements 10 I could import an SWF perfectly well, even animted swf's
However, in PPro CS6, When I import it, it actually corrupts the file so that not all the objects display.
And this is how I proved it...
1) Created the SWF in FlashPro CS6
2) View SWF from within Windows Explorer... works perfectly!!
3) Made a COPY of the created SWF
4) Imported the original SWF into PPro CS6... not all objects show in the Monitor
5) I go back into Windows Explore and view SWF... and sure enough... some of the objects don't show up.
6) I view the COPY of the swf in Windows Explorer I made... AND ALL IS FINE
7) For good measure, I import the SWF into Elements... and it doesn't work either!!
And to kick myself in the head even more...
Before I joined the cloud... Flash SWF's worked perfectly in a trial version of PPro CS6.
Very dissapointed none the least.
What is with that?
I don't get it.
What is wrong with the import of SWF into PPro CS6
    Jul 1, 2012 1:13 PM   in reply to fwhilton
    Do you have the Write XMP ID To Files On Import preference enabled? If so, disable it, and then try again.
    Jul 1, 2012 6:11 PM   in reply to fwhilton
    The XMP ID is a piece of metadata written into the file to identify it. Apparently, it is being injected in a way that damages the SWF file.
    Please submit a bug report here so that the Premiere Pro engineers know that this has impacted you:
    http://adobe.ly/ReportBug
    Jul 20, 2012 1:14 PM   in reply to Todd_Kopriva
    I was having the same problem. I disabled the XMP ID and the file is no longer being corrupted. However, the .swf file won't play at all. My sequence is just black. What am I doing wrong?
    Jul 24, 2012 1:13 PM   in reply to SyneoMarketing
    I have the same problem. I have a SWF file that I try to Import to Premier Pro CS5. When it imports it only shows it as being 1 second long and there's nothing to playback despite the SWF file playing fine and being over 28 seconds long? I imported the audio separately and it's fine. I've tried the above and it's still not working. How come?
    Sep 24, 2012 12:59 PM   in reply to Quadzilla_1111
    I am having this problem as well. Did anyone figure out the solution. Thanks
