Add fade to rotating image javascript
Jun 29, 2012 6:15 AM
I have managed to get a tating image working with the following javascript:
<script type="text/javascript">
(function() {
    var rotator = document.getElementById('rotator');
    var imageDir = '';
    var delayInSeconds = 5;
    var images = ['h-images/homepage.jpg', 'h-images/rentalspage.jpg', 'h-images/investpage.jpg'];
    var num = 0;
    var changeImage = function() {
        var len = images.length;
        rotator.src = imageDir + images[num++];
        if (num == len) {
            num = 0;
    setInterval(changeImage, delayInSeconds * 1000);
</script>
the page is www.helenmarino.com/test.html (you may have to refresh the page)
I am surprised I managed to get this far so any simple code added to make the images fade nicely would be greatly appreciated.
many thanks
Helen
    Jun 29, 2012 6:55 AM   in reply to Helen Marino
    Jun 29, 2012 8:30 AM   in reply to Helen Marino
    I like jQuery Cycle.
    http://jquery.malsup.com/cycle/
    Nancy O.
    Jun 30, 2012 3:03 PM   in reply to Helen Marino
    Download the Cycle plug-in script and save it to your local site folder.  I prefer to keep scripts in my Scripts folder but that's up to you.
    http://jquery.malsup.com/cycle/download.html
    jQuery has 3 basic parts to it:
    • the core code library which you ref in your <head>
    • the plug-in script & css (if any) which you ref in your <head>
    • the function code inside <script> tags -- I prefer to put this above closing </body> tag.
    <head>
    <!-- jQuery latest core library -->
    <script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js">
    </script>
    <!-- Cycle plugin -->
    <script type="text/javascript" src="Scripts/jquery.cycle.all.latest.js"></script>
    </head>
    <body>
    <div class="slideshow">
         <img src="image1.jpg" width="200" height="200" alt="description" />
         <img src="image2.jpg" width="200" height="200" alt="description" />
         <img src="image3.jpg" width="200" height="200" alt="description" />
         <img src="image4.jpg" width="200" height="200" alt="description" />
    </div>
    <!--Cycle function code-->
    $(document).ready(function() {
        $('.slideshow').cycle({
    fx: 'fade'
    </script>
    </body>
    That's all there is to it.  If you want anything fancier, look at Cycle's More Demos & Examples near the bottom of their home page.
    Nancy O.
    Jun 30, 2012 4:43 PM   in reply to Helen Marino
    Everything looks fine except I don't see the jquery.cycle.js file on your remote server.  Did you upload it?
    404 Not found
    Nancy O.
    Jul 1, 2012 9:46 AM   in reply to Helen Marino
    What did you name your script?
    Is it inside the Scripts folder? (uppercase S)
    The devil is in the details...
    Nancy O.
    Jul 1, 2012 1:39 PM   in reply to Helen Marino
    I sometimes get timed out by my server or when my internet connection becomes slower than normal.  It's usually a temporary glitch.  Try uploading your files again.
    Nancy O.
    Jul 1, 2012 1:59 PM   in reply to Helen Marino
    Boils down to a path/naming problem.
    Change this in your page:
    to this:
    <script type="text/javascript" src="jquery.cycle.all.js"></script>
    Nancy O.
    Jul 1, 2012 3:11 PM   in reply to Helen Marino
    From this page:
    http://jquery.malsup.com/cycle/int2.html
        fx:     'fade',
        speed:   800,  //speed in milliseconds
        timeout: 3000,
        next:   '.slideshow',
        pause:   1
    </script>
    Nancy O.
    Jul 1, 2012 3:42 PM   in reply to Helen Marino
    add this on line 134.
    N
    Jul 1, 2012 4:00 PM   in reply to Helen Marino
    Looks great!
    N
