CS5 let me use Photoshop's Image Processor from Bridge; has it been removed for CS6?
Go to Startup Scripts and make sure there is a check mark for at least Bridge and Photoshop.
All startup scripts are checked. Still no Photoshop option.
If Photoshop does not show, reset the preferences. Hold down Crtl key and start bridge. You should get a reset window.
Resetting the preferences didn't work. Do I need to uninstall, run the cleaner tool and reinstall?
not yet.
Can you start image processor from PS? That should tell you if it is working or not.
Image Processor works fine from Photoshop. Thanks for your help!
Uninstalled, ran the cleaner tool and reinstalled. All's well.
