Hi all
This code workks binding a cfinput in an HTML cfform:
Name:<cfinput type="text" name="FIRSTNAME" label="Name" required="yes" width="150" bind="{UsersGrid.FIRSTNAME}" >
However this href doesn't seem to bind correctly:
<a href="http://www.google.com/search?hl=en&output=search&sclient=psy-ab&q={Use rsGrid.COMPANY}&btnK=" bind="{UsersGrid.COMPANY}">Google.com</a>
This cfselect doesn't either:
Department: <cfselect name="DEPARTMENT1" width="100" size="1" label="Department" required="yes" bind="UsersGrid.DEPARTMENT1">
<option></option><cfoutput query="dNames"><option value="#DEPARTMENTIDS#">#DEPARTMENTNOM#</option></cfoutput>
</cfselect>
How can I make them both work? Thank you
[...]This cfselect doesn't either:
Hi goodychurro1,
The tag you're looking for is cfajaxproxy. Here is a example to get you started (if you're on CF9, just remove the 3rd attribute from the queryNew() and then populate the query using a queryAddRow() and three querySetCell()s):
<cfset q = queryNew("myID,myString", "integer,varchar", [[1,"one"],[2,"two"],[3,"three"]]) />
<cfajaxproxy bind="javascript:myHandler({myGrid.myID})" />
<script type="text/javascript">
function myHandler(myID) {
//update the link's href
document.getElementById('myLink').href = 'http://www.coldfusion.com?q=' + myID;
//update the select's selected
var theField = document.getElementById('mySelect');
for(var i=0; i<theField.options.length; i++) {
if(theField.options[i].value==myID) {
theField.options[i].selected = true;
} else {
theField.options[i].selected = false;
</script>
<cfform>
<cfgrid name="myGrid" format="html" width="200" query="q">
<cfgridcolumn name="myID" />
<cfgridcolumn name="myString" />
</cfgrid>
<cfselect name="mySelect" query="q" display="myString" value="myID" />
</cfform>
<a href="" id="myLink" target="_blank">text</a>
Selecting a row in the grid changes the link's href and the select's selected option.
References:
- a blog post that might be of help
-Aaron
Hi Aaron
I put this code before my cfform tag, and changed the mygrid to the name of my grid (usersgrid):
<cfajaxproxy bind="javascript:myHandler({UsersGrid.myID})" />
} else {
</script>
I then added this code in the cfform, but the link is shown as http://www.coldfusion.com?q=undefined - why is this? Thanks:
Hi goodychurro1,
In the {UsersGrid.myID}, the 'myID' corresponds to <cfgridcolumn name="myID" />.
Meaning, you should change the 'myID' to be the same name as one of your grid columns. If you currently don't have a grid column w/ the name 'myID', then the href's resultant URL would end w/ 'undefined'.
-Aaron
Hi Aaaron
I changed it to my cfgrid column name, COMPANY but it is still showing "undefined" and none of the other fields bind anymore
function myHandler(COMPANY) {
document.getElementById('myLink').href = 'http://www.coldfusion.com?q=' + COMPANY;
if(theField.options[i].value==COMPANY) {
} else {
</script>
Hi Aaron yes but that doesn't work.
<cfajaxproxy bind="javascript:myHandler({UsersGrid.COMPANY})" />
var theField = document.getElementById('SECTORS1');
if(theField.options[i].value==SECTORS1) {
} else {
</script>
I got rid of all the cfajaxproxy code and just tried to bind the cfselect directly, but I get this error: Bind failed for select box SECTORS1 bind value is not a 2D array or valid serialized query
<td>Sector:<cfselect class="input" name="SECTORS1" size="1" label="Sector" required="yes" bind="{UsersGrid.SECTORS1}">
<option></option><cfoutput query="industries"><option value="#SECTORSIDS#">#SECTORSNOM#</option></cfoutput>
</cfselect> </td>
Hi goodychurro1,
Regarding the href (we'll discuss the cfselect next), could you please try this:
</script>
-Aaron
Excellent! Now we'll try adding the cfselect. Could you try this?
<cfajaxproxy bind="javascript:myHandler({UsersGrid.COMPANY},{UsersGrid.SECTORS1})" />
function myHandler(COMPANY,SECTORS1) {
//update SECTORS1's selected
} else {
</script>
Sector:<cfselect class="input" name="SECTORS1" size="1" label="Sector" required="yes">
<option></option><cfoutput query="industries"><option value="#SECTORSIDS#">#SECTORSNOM#</option></cfoutput></cfselect>
-Aaron
Thanks aaron that works perfectly. I have another cfselect which I have now formatted in the same way:
<cfselect class="input" name="DEPARTMENT1" size="1" label="Department" required="yes">
<option></option><cfoutput query="dNames"><option value="#DEPARTMENTIDS#">#DEPARTMENTNOM#</option></cfoutput></cfselect >
I copied the script code that works for the one cfselect and changed it but it doesn't seem to bind, it must be a script issue?:
//update DEPARTMENT1's selected
var theField = document.getElementById('DEPARTMENT1');
if(theField.options[i].value==DEPARTMENT1) {
} else {
Hi goodychurro1,
Excellent that it is working! For additional cfselects, just be sure to also add those grid column names to the cfajaxproxy and the myHandler function. Like so:
change <cfajaxproxy bind="javascript:myHandler({UsersGrid.COMPANY},{UsersGrid.SECTORS1})" /> to <cfajaxproxy bind="javascript:myHandler({UsersGrid.COMPANY},{UsersGrid.SECTORS1},{UsersGrid.DEPARTMENT1})" />
and change
function myHandler(COMPANY,SECTORS1) to function myHandler(COMPANY,SECTORS1,DEPARTMENT1)
B/c cfajaxproxy needs to know about those grid column names, so it can pass the values of each to myHandler(). And myHandler() itself needs to know about the values, so that it can use them.
-Aaron
Thanks Aaaron I tried the code but there seems to be an error in the //update DEPARTMENT1's selected -something with the js conditions?
<cfajaxproxy bind="javascript:myHandler({UsersGrid.COMPANY},{UsersGrid.SECTORS1},{ UsersGrid.DEPARTMENT1})" />
function myHandler(COMPANY,SECTORS1,DEPARTMENT1) {
document.getElementById('myLink').href = 'http://www.google.com/search?q=' + COMPANY;
document.getElementById('Linkedin').href = 'http://www.google.com/search?q=linkedin+' + COMPANY;
} else {
} else {
</script>
Hi goodychurro1,
The issue was created when copying/pasting the '//update SECTORS1's selected' section of code. The myHandler()'s closing '}' was selected during the copy. And the copied code was pasted outside of the myHandler() function. Please try this:
} else {
} else {
</script>
-Aaron
Hi Aaaron it still isn't binding, maybe it's something to do with the fact that the cfgridcolumn name is different?
<cfgridcolumn name="DEPARTMENTNOM" width="150" header="Department">
Code:
<cfajaxproxy bind="javascript:myHandler({UsersGrid.COMPANY},{UsersGrid.SECTORS1},{ UsersGrid.DEPARTMENTNOM})"/>
document.getElementById('Linkedin').href = 'http://www.google.com/search?q=linkedin' + COMPANY;
} else {
} else {
</script>
Hi goodychurro1,
Please see that I've made DEPARTMENTNOM and DEPARTMENTIDS bold. When selecting a row in the UsersGrid, the grid's DEPARTMENTNOM column value must match one of the DEPARTMENT1's option values.
Question 1: Does <cfgridcolumn name="DEPARTMENTNOM" grid column display a department name in each grid row, or does it display a department ID in each grid row?
Question 2: Does the DEPARTMENT1 cfselect have a single ID for each option's value, or something else for each option's value?
Question 3: Are there any matches between what the grid's DEPARTMENTNOM column is displaying and any of the select's option values?
-Aaron
<cfquery name="qNames" datasource="salesdb">
select * from company, industries, division
where company.SECTORS1 = industries.SECTORSIDS
<cfif structKeyExists(url,"sectorid")>
and industries.SECTORSIDS = #url.sectorid#</cfif>
and division.DEPARTMENTIDS = company.DEPARTMENT1
and company.WHEN = 2
ORDER BY company</cfquery>
<cfquery name="dNames" datasource="salesdb">
select DEPARTMENTIDS, DEPARTMENTNOM
from division
order by DEPARTMENTNOM</cfquery>
It displays a department name in each grid row, it outputs this from the qName query
A single ID for each option's value
Department:<cfselect class="input" name="DEPARTMENT1" size="1" label="Department" required="yes">
There are but they are not being shown in the html form. In the cfflash form the bind happened with:
<cfselect name="DEPARTMENT1" width="100" size="1" label="Department" required="yes" onchange="UsersGrid.dataProvider.editField(UsersGrid.selectedIndex, 'DEPARTMENT1', DEPARTMENT1.selectedItem.data);">
</cfselect>
[...]and division.DEPARTMENTIDS = company.DEPARTMENT1
[...]</cfquery>
Hi goodychurro1,
It sounds like you actually want to bind the cfselect to the grid's DEPARTMENT1 column. In that case, could you please change the cfaxaxproxy to this:
<cfajaxproxy bind="javascript:myHandler({UsersGrid.COMPANY},{UsersGrid.SECTORS1},{ UsersGrid.DEPARTMENT1})"/>
-Aaron
Hmm no that doesn't work, it doesn't give an error but it just doesn't bind the DEPARTMENT1 field. In the flash cfform I also had this on the cfgrid onchange which may be relevant?:
for (var i:Number = 0; i<DEPARTMENT1.length; i++) {if (DEPARTMENT1.getItemAt([i]).data == UsersGrid.selectedItem.DEPARTMENT1) DEPARTMENT1.selectedIndex = i}
Here the updated code:
} else {
} else {
</script>
Hi Aaron, yes it does:
<cfform name="SFORM" FORMAT="html" width="1000" height="400" style="margin-left:140px;">
<cfgrid name="UsersGrid"
FORMAT="html"
query="QNAMES" width="920" height="200" rowheaders="No" striperows="yes" striperowcolor="fefefe">
<cfgridcolumn name="RANKING" width="40"header="Rank">
<cfgridcolumn name="COMPANY" width="170" header="Company">
<cfgridcolumn name="FIRSTNAME" header="Contact Name">
<cfgridcolumn name="POS" width="160" header="Position">
<cfgridcolumn name="SECTORSNOM" width="120" header="Sectors">
<cfgridcolumn name="ABUNDANCE" width="120" header="Action date">
<cfgridcolumn name="SECTORS1" width="120" header="Action date" display="no">
<cfgridcolumn name="PRICE" width="120" header="Action date" display="no">
<cfgridcolumn name="PHONE" width="120" header="Action date" display="no">
<cfgridcolumn name="EMAIL" width="120" header="Action date" display="no">
<cfgridcolumn name="MOBILE" width="120" header="Action date" display="no">
<cfgridcolumn name="ADDRESS" width="120" header="Action date" display="no">
<cfgridcolumn name="CITY" width="120" header="Action date" display="no">
<cfgridcolumn name="COMMENTS" width="120" header="Action date" display="no">
<cfgridcolumn name="MTGT" width="120" header="Action date" display="no">
</cfgrid>
Hi goodychurro1,
If you can post the entire .cfm for this, I can try to help further. I have your database tables setup per your other thread here: http://forums.adobe.com/thread/1031327
Thanks!,
-Aaron
Message was edited by: itisdesign
Sure, Aaaron here it is, it uses the same database tables and datasource as in the other thread:
<cfquery name="QNAMES" datasource="tester">
<cfquery name="dNames" datasource="tester">
from division
<CFQUERY name="industries" datasource="tester">
SELECT * FROM industries
</CFQUERY>
<CFQUERY name="salesstep" datasource="tester">
SELECT * FROM sales
</CFQUERY>
<CFQUERY name="xity" datasource="tester">
SELECT * FROM ciudad
</CFQUERY>
<CFQUERY name="hols" datasource="tester">
SELECT * FROM holidays
</CFQUERY>
<!--- UPDATE QUERY --->
<cfif isDefined("FORM.UPDATEADDBTN")>
<cfif FORM.ENTID GTE 1>
<cfset isCOMPANYNull = iif(len(trim(FORM.COMPANY)) EQ 0, true, false)>
<cfset isSECTORS1Null = iif(len(trim(FORM.SECTORS1)) EQ 0, true, false)>
<cfset isRANKINGNull = iif(len(trim(FORM.RANKING)) EQ 0, true, false)>
<cfset isPRICENull = iif(len(trim(FORM.PRICE)) EQ 0, true, false)>
<cfset isDEPARTMENT1Null = iif(len(trim(FORM.DEPARTMENT1)) EQ 0, true, false)>
<cfset isFIRSTNAMENull = iif(len(trim(FORM.FIRSTNAME)) EQ 0, true, false)>
<cfset isPOSNull = iif(len(trim(FORM.POS)) EQ 0, true, false)>
<cfset isPHONENull = iif(len(trim(FORM.PHONE)) EQ 0, true, false)>
<cfset isEMAILNull = iif(len(trim(FORM.EMAIL)) EQ 0, true, false)>
<cfset isMOBILENull = iif(len(trim(FORM.MOBILE)) EQ 0, true, false)>
<cfset isADDRESSNull = iif(len(trim(FORM.ADDRESS)) EQ 0, true, false)>
<cfset isCITYNull = iif(len(trim(FORM.CITY)) EQ 0, true, false)>
<cfset isCOMMENTSNull = iif(len(trim(FORM.COMMENTS)) EQ 0, true, false)>
<cfset MEETINGDATE = trim(FORM.ABUNDANCE)>
<!--- DATECFM--->
<cfset isMTGTNull = iif(len(trim(FORM.MTGT)) EQ 0, true, false)>
<cfset isSTATE1Null = iif(len(trim(FORM.STATE1)) EQ 0, true, false)>
<CFQUERY name="updatecompany" datasource="tester">
update COMPANY
SET COMPANY = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(FORM.COMPANY)#" null="#isCOMPANYNull#" />,
SECTORS1 = <cfqueryparam cfsqltype="cf_sql_integer" value="#trim(FORM.SECTORS1)#" null="#isSECTORS1Null#" />,
RANKING = <cfqueryparam cfsqltype="cf_sql_integer" value="#trim(FORM.RANKING)#" null="#isRANKINGNull#" />,
PRICE = <cfqueryparam cfsqltype="cf_sql_integer" value="#trim(FORM.PRICE)#" null="#isPRICENull#" />,
DEPARTMENT1 = <cfqueryparam cfsqltype="cf_sql_integer" value="#trim(FORM.DEPARTMENT1)#" null="#isDEPARTMENT1Null#" />,
FIRSTNAME = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(FORM.FIRSTNAME)#" null="#isFIRSTNAMENull#" />,
POS = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(FORM.POS)#" null="#isPOSNull#" />,
PHONE = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(FORM.PHONE)#" null="#isPHONENull#" />,
EMAIL = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(FORM.EMAIL)#" null="#isEMAILNull#" />,
MOBILE= <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(FORM.MOBILE)#" null="#isMOBILENull#" />,
ADDRESS = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(FORM.ADDRESS)#" null="#isADDRESSNull#" />,
CITY = <cfqueryparam cfsqltype="cf_sql_integer" value="#trim(FORM.CITY)#" null="#isCITYNull#" />,
COMMENTS = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(FORM.COMMENTS)#" null="#isCOMMENTSNull#" />,
ABUNDANCE = <cfqueryparam cfsqltype="cf_sql_timestamp" value="#MEETINGDATE#" />,
MTGT = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(FORM.MTGT)#" null="#isMTGTNull#" />,
STATE1 = <cfqueryparam cfsqltype="cf_sql_integer" value="#trim(FORM.STATE1)#" null="#isSTATE1Null#" />
WHERE ENTID = #FORM.ENTID#
</CFQUERY>
<CFLOCATION URL="testht.cfm?begin=1">
<cfelse>
<!--- DATECFM --->
<!--- ADD COMPANY QUERY --->
<CFQUERY name="addcompany" datasource="tester">
INSERT INTO COMPANY(
COMPANY,
SECTORS1,
RANKING,
PRICE,
DEPARTMENT1,
FIRSTNAME,
POS,
PHONE,
EMAIL,
MOBILE,
ADDRESS,
CITY,
COMMENTS,
ABUNDANCE,
MTGT,
STATE1
VALUES (
</CFQUERY>
<!---DATE_FORMAT(datetime_field_name,'%Y-%m-%d');--->
</cfif>
</cfif>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Sales</title>
<link rel="stylesheet" href="style.css" type="text/css" media="screen" />
<link rel="stylesheet" href="formst.css" type="text/css" media="screen" />
</head>
<cfdump var=#qnames#>
} else {
</script>
<!--- TOP --->
<body>
<div>
FORMAT="html"
</cfgrid>
<!---FIRST--->
<table width="880" class="stat" >
<tr><td><cfoutput>#QNAMES.RecordCount# Companies</cfoutput></td></tr>
<tr>
<td>Company:<cfinput class="input" type="text" name="COMPANY" size="20" label="Company" required="yes" bind="{UsersGrid.COMPANY}" ></td>
<td>
</td>
<td>Ranking:<cfinput class="input" type="TEXT" name="RANKING" size="3" label="Ranking" bind="{UsersGrid.RANKING}" ></td>
<td>Price:<cfinput class="input" type="TEXT" name="PRICE" size="3" label="Price" bind="{UsersGrid.PRICE}" >
<a href="" id="myLink" target="_blank">Google</a>
<a href="" id="Linkedin" target="_blank">Linkedin</a></td>
</tr>
<tr>
<td>Department:<cfselect class="input" name="DEPARTMENT1" size="1" label="Department" required="yes">
</td>
<td>Name:<cfinput class="input" type="text" name="FIRSTNAME" label="Name" required="yes" width="150" bind="{UsersGrid.FIRSTNAME}" ></td>
<td>Position:<cfinput class="input" type="text" name="POS" label="Position" width="150" bind="{UsersGrid.POS}" ></td>
<td>Phone:<cfinput class="input" type="text" name="PHONE" label="Phone" width="150" bind="{UsersGrid.PHONE}" ></td>
</tr>
<!--- THIRD--->
<tr><td>Email:<cfinput class="input" type="text" name="EMAIL" label="Email" width="150" bind="{UsersGrid.EMAIL}" ></td>
<td>Mobile:<cfinput class="input" type="text" name="MOBILE" label="Mobile" bind="{UsersGrid.MOBILE}" ></td>
<td>Address:<cfinput class="input" type="text" name="ADDRESS" label="Address" bind="{UsersGrid.ADDRESS}" ></td>
<td><cfselect class="input" name="CITY" width="80" size="1" >
<cfoutput query="xity"><option value="#CITYID#">#CITYNOM#</option></cfoutput>
</cfselect></td>
</tr>
<!--- FOURTH --->
<tr><td>Comments:<cftextarea class="input" name="COMMENTS" height="60" label="Comments" bind="{UsersGrid.COMMENTS}" /> </td>
<td>Action:<cfinput type="DateField" class="input" size="10" name="ABUNDANCE" label="Action" bind="{UsersGrid.ABUNDANCE}" ></td>
<td>Time:<cfselect class="input" name="MTGT" width="90" label="Time"><option>7:00AM</option></cfselect></td>
<td><cfselect class="input" name="STATE1" size="1" label="Action" >
<cfoutput query="salesstep"><option value="#SALESID#">#SALESNOM#</option></cfoutput>
</cfselect> </td>
<cfinput type="hidden" name="ENTID" label="ENTID" bind="{UsersGrid.ENTID}" >
</tr>
<tr> <td>
<cfinput type="submit" name="DELCOM" value="delete" class="button" >
<cfinput type="submit" name="UPDATEADDBTN" value="UPDATE or ADD NEW" class="button"></td>
</tr>
</table>
</cfform>
<cfif isDefined("FORM.DELCOM")>
<CFQUERY name="deletecompany" datasource="tester">
DELETE FROM COMPANY
</CFQUERY>
<CFLOCATION URL="testht.cfm">
</cfif>
</div>
</body>
</html>
Hi goodychurro1,
Just add this grid column: <cfgridcolumn name="DEPARTMENT1" display="no">. Then the bind will work w/ this:
} else {
} else {
</script>
Basically, a bind needs matching values. The grid's new DEPARTMENT1 column contains the numeric values that match up to the DEPARTMENT1 cfselect's values. The reason the DEPARTMENTNOM grid column isn't a good candidate for the bind, is b/c it contains the string values of the department names.
-Aaron
