Dear All,
I have created a PDF fillable form with a button which save & print the pdf.
The code for is as fallow:
Formular1.#pageSet[0].Seite1.Bildfeld1::click - (JavaScript, client)
var Mailto = "info@stell.de";
var Betreff = Textfeld1.rawValue;
var Nachricht = "Dies ist eine Telefonnotiz\r2.Zeile Hier";
var CC = "info@stell.de";
var BCC = "info@stell.de";
var Mail = "mailto:" + Mailto + "?Subject=" + Betreff + "&Body=" + Nachricht + "&cc=" + CC + "&bcc=" + BCC;
cURL: Mail,
bEmpty: false,
cSubmitAs: "PDF"
Formular1.#pageSet[0].Seite1.DruckenSchaltfläche1::click - (JavaScript, client)
my problem now is that with this script I can print and save the file even though all required fields are not filled!! I donot anyone to have the possibility to print the file or save it unless he fill all required fileds.
Solved! Go to Solution.
Total Likes
HI,
you can use the validate element to prevent users from printing a form.
See: http://forms.stefcameron.com/2008/04/13/prevent-printing-pdf-forms-in-acrobat-8/
But you never can prevent users from saving a form.
Total Likes
HI,
Total Likes
I just wanted to allow the users to print the PDF or save it ONLY when they have filled the entir document. this is not possible at all?
Total Likes
can I send you the document to know what I mean?
I canot upload it over here?
Total Likes
Please read the article under the link I posted before.
There you'll get all details of how to prevent the printing and a sample form you can work with.
Keep in mind that it isn't possible to prevent the saving, this only works for printing, submitting and data connections.
Total Likes
Thanks a lot for your reply
I sow the article, but the only problem is that the source code for the print button is exactly what I write and I cannot integrate the element code in it. Since in the article is says change the source code and look for
XML Source in Designer and find the following mark-up about 2/3 way down:
<config xmlns="http://www.xfa.org/schema/xci/1.0/">
<agent name="designer">
</agent>
<present>
<!-- [0..n] -->
I don’t have this part in my script!
Total Likes
What version of Designer do you use?
Total Likes
Version 9
Total Likes
Ok,
than you need to add the validate element under the <config> tag as it doesn't exist by default.
Before:
<config xmlns="http://www.xfa.org/schema/xci/3.0/">
<!-- [0..n] -->
<destination>pdf</destination>
<pdf>
<!-- [0..n] -->
<fontInfo/>
</pdf>
</agent>
<present>
<!-- [0..n] -->
<pdf>
<!-- [0..n] -->
<fontInfo/>
<version>1.7</version>
<adobeExtensionLevel>5</adobeExtensionLevel>
</pdf>
<xdp>
<packets>*</packets>
</xdp>
</present>
</config>
After:
<!-- [0..n] -->
<pdf>
<!-- [0..n] -->
<fontInfo/>
</pdf>
</agent>
<present>
<!-- [0..n] -->
<pdf>
<!-- [0..n] -->
<fontInfo/>
</pdf>
<xdp>
</xdp>
</present>
<!-- This is the validate element to prevent printing, when mandatory fields are empty -->
<acrobat>
<validate>prePrint</validate>
</acrobat>
</config>
Total Likes
and where should I insert this code?
Total Likes
Go to the XML-Source and look for the <config> tag and add this snippet.
<acrobat>
</acrobat>
Total Likes
I donot want to ask silly questions , but really I canot find the XML source code. all what I can find is this:
event.target.submitForm({
cURL: Mail,
bEmpty: true,
cSubmitAs: "PDF"
xfa.host.print(1, "0", (xfa.host.numPages -1).toString(), 0, 0, 0, 0, 0);
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1.#subform[1].#subform[2].Teilformularschaltfläche1entfernen::click - (JavaScript, client)
This button will Remove the current instance of the repeating subform or table row.
bCalc: Flag - true if the removed instance might be referenced by other calculations, otherwise false.
message: The error message displayed.
var bCalc = true;
var message = "Sie haben die Mindestanzahl zulässiger Objekte erreicht.";
// DO NOT MODIFY THE CODE BEYOND THIS POINT - 9.0.0.2.20101008.1.725030.725025 - Subform_Instance_Controls_IRM.xfo.p4
var oWrapper = this.parent.parent; // The outer subform built in to the object, enclosing the button group.
var oTargetSubform = oWrapper.parent; // The subform or table row the controls are intended to manipulate.
var oManager = oTargetSubform.instanceManager; // Get the instance manager.
var nMinCount = oManager.occur.min; // Get the minimum number of subform occurrences allowed.
var nSubCount = oManager.count; // Get the current number of instances.
// Proceed if the minimum number of subform occurrences has not been reached.
if (nSubCount > nMinCount) {
// Invoke the Instance Manager.
oManager.removeInstance(oTargetSubform.index);
// Fire the form calculations.
if (bCalc == true) {
// Execute all the form calculations.
xfa.form.recalculate(1);
} else {
xfa.host.messageBox(message,"Remove Item", 3);
// END OF DO NOT MODIFY
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1.#subform[1].#subform[2].Teilformularschaltfläche1hinzufügen::click - (JavaScript, client)
This button will insert one instance of the repeating subform or table row.
bCalc: Flag - true if the new instance might be referenced by other calculations, otherwise false.
var bCalc = true;
var message = "Sie haben die maximale Anzahl zulässiger Objekte erreicht.";
// DO NOT MODIFY THE CODE BEYOND THIS POINT - 9.0.0.2.20101008.1.725030.725025 - Subform_Instance_Controls_IRM.xfo.p2
var nMaxCount = oManager.occur.max; // Get the maximum number of subform occurrences allowed.
// Proceed if the maximum number of subform occurrences has not been reached.
if ((nMaxCount == "-1") || (nSubCount < nMaxCount)) {
var oNewInstance = oManager.addInstance(1);
// Move the new subform below the current one.
var nIndexFrom = oNewInstance.index;
var nIndexTo = oTargetSubform.index + 1;
oManager.moveInstance(nIndexFrom, nIndexTo);
} else {
xfa.host.messageBox(message,"Insert Item", 3);
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1.#subform[1].#subform[2].TeilformularschaltflächeNachOben1::click - (JavaScript, client)
This button will move the current instance of the repeating subform or table row up one position.
bCalc: Flag - true if the moved instance might be referenced by other calculations, otherwise false.
var bCalc = true;
var message = "Das aktuelle Objekt kann nicht nach oben verschoben werden, da es sich bereits an erster Stelle befindet.";
// DO NOT MODIFY THE CODE BEYOND THIS POINT - 9.0.0.2.20101008.1.725030.725025 - Subform_Instance_Controls_IRM.xfo.p1
var nIndex = oTargetSubform.index // Get the index number of the current subform or table row.
// Proceed if the current subform is not the first instance.
if (nIndex != 0) {
// Move the current subform.
var nIndexFrom = nIndex;
var nIndexTo = nIndex - 1;
} else {
xfa.host.messageBox(message,"Move Item", 3);
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1.#subform[1].#subform[2].TeilformularschaltflächeNachUnten1::click - (JavaScript, client)
This button will move the current instance of the repeating subform or table row down one position.
var bCalc = true;
var message = "Das aktuelle Objekt kann nicht nach unten verschoben werden, da es sich bereits an letzter Stelle befindet.";
// DO NOT MODIFY THE CODE BEYOND THIS POINT - 9.0.0.2.20101008.1.725030.725025 - Subform_Instance_Controls_IRM.xfo.p3
// Proceed if the current subform is not the last instance.
if ((nIndex + 1) < nSubCount) {
var nIndexTo = nIndex + 1;
} else {
Formular1.#subform[1].#subform[2].Tabelle3.Zeile1::indexChange - (JavaScript, both)
//{{Adobe LiveCycle Designer Generated Code Begin}} - row shading script. Don't modify it!
var Freqs=[1,1];
var Colors=["255,255,255","255,255,255"];
var nFreqSize = 0;
for (var i=0; i<Freqs.length; i++)
nFreqSize += Freqs[i];
var nRelIndex = this.index % nFreqSize + 1;
for (var nRun=0; nRun<Freqs.length; nRun++)
if (nRelIndex>Freqs[nRun])
nRelIndex -= Freqs[nRun];
else
this.border.fill.color.value = Colors[nRun];
break;
//{{Adobe LiveCycle Designer Generated Code End}} - row shading script.
Formular1.TABELLEN1.#subform[2].Tabelle4.Zeile1::indexChange - (JavaScript, both)
var Freqs=[1,1];
var nFreqSize = 0;
else
break;
would you like to take alook with team viewer ... only If you have time?
Total Likes
<config xmlns="http://www.xfa.org/schema/xci/2.8/">
<!-- [0..n] -->
<pdf>
<!-- [0..n] -->
<fontInfo/>
</pdf>
</agent>
<present>
<!-- [0..n] -->
<pdf>
<!-- [0..n] -->
<adobeExtensionLevel>3</adobeExtensionLevel>
</pdf>
<common/>
<script>
<runScripts>server</runScripts>
</script>
<cache>
<macroCache/>
</cache>
<xdp>
</xdp>
<psMap>
<font typeface="NewsGoth BT" psName="NewsGothicBT-Roman" weight="normal" posture="normal"/>
<font typeface="NewsGothic LT" psName="NewsGothicLT" weight="normal" posture="normal"/>
<font typeface="NewsGothic LT" psName="NewsGothicLT-Bold" weight="bold" posture="normal"/>
<font typeface="NewsGothic LT" psName="NewsGothicLT-BoldOblique" weight="bold" posture="italic"/>
<font typeface="NewsGothic LT" psName="NewsGothicLT-Oblique" weight="normal" posture="italic"/>
</psMap>
<acrobat>
</acrobat>
</config>
** I found it & i have inserted the code! but its not working?
TeamViewer is ok, but not at the moment.
Do you have time this evening at around 19:00?
Or can you share your form somewhere and post a link here?
Total Likes
the problem is iam working in a company from 7:00 till 17:00 (Germany time)
and all the programes & the sheets at my desktop computer , but if you have time tomorrow it will be perfect. sorry for all this mess, I have been trying to solve this issues but iam new in the field of java scrptiing
Total Likes
Keine Ursache.
Bis morgen dann!
Total Likes
l0o0ol danke
Total Likes
