CouponPages.Com
Is there a way for export to create rounded corners?
Jun 30, 2012 9:27 AM
Tags: #export #css #fireworks #cs6 #rounded #corners
I love creating layouts with Fireworks, but it always bothered me that it didn't recreate any rounded corners.
When CS6 came out with the CSS Properties window, I was happy to see that the CSS in the Properties window faithfully created my objects with rounded corners, so I had high hopes that the regular export would include this markup... but it didn't.
My current work-around seems very frustrating.  I export my file as HTML with CSS images... I get a perfectly rendered page with one exception... the corners are still square.   Then, I go back to Fireworks, open the CSS Properties window, then cut and paste the tags for the corners one by one into the CSS file.
It seems to me with such heavy emphasis on CSS integration, that  the export function should include the this code too.
Am I doing something wrong?  Or is this still an unsupported feature?
    Jun 30, 2012 9:46 AM   in reply to CouponPages.Com
    Use the CSS Properties panel to extract and copy CSS for the selected object on the canvas. It has no integration with the CSS and Images export workflow OR the HTML and Images export workflow (the latter of which produces a rigid, image-based, html table layout). HTML and Images export is really only suitable for clickable prototypes. CSS and Images export is really only suitable if you like re-writing all the CSS to match your normal workflow.
    General workflow:
    1) Add effects to vector shape (corners, drop shadow, glow, gradient fill, border, opacity, etc..)
    2) Open CSS Properties panel. CSS properties for selected object are displayed.
    3) Click the Copy All button in the panel.
    4) Switch to Dreamweaver or your preferred web editor.
    5) Paste the CSS into the desired class, id or element rule.
    6) View in Live View or Preview in Browser to see results.
    HTH
    Jun 30, 2012 8:06 PM   in reply to CouponPages.Com
    No one can say for sure what changes/improvements will occur, but considering little has been done with the CSS and image export in two releases, I wouldn't hold my breath. The panel is far easier for Adobe to update quickly as specs change. The export workflow though, is baked right into FW.
    Cast your vote, though by requesting this feature be added, by using the Adobe wish form. Without feedback to the wish form, the engineering team isn't aware or what users want changed.
    Jul 1, 2012 11:45 PM   in reply to CouponPages.Com
    Thank you for posting this question and obtaining an answer..I had the same questions.
    Thx
