Just watched a Julieanne Kost video about creating a 32-bit (HDR) image in LR 4.1. I tried this technique and after importing the HDR 32-bit image back into LR 4.1 (from Photoshop CS5 HDR Pro) the resultant image is blank with a warning triangle that reads "Lightroom has encountered problems reading this photo. You will not be able to make adjustments to the photo. Would anyone have an idea why this happened?
Phil
iMac, OSX 10.6.8, 4 GB Ram
Victoria,
Thank you for the quick and correct reply. I had saved the HDR image in PSD format; didn't realize that it had to be TIFF or DNG. I'm not sure if Julieanne mentioned that in the video. Oddly, back in LR4.1, when I right click on the TIFF 32-bit file to "Edit a Copy with Lightroom Adjustments" in Photoshop, it does not open the image. However, the image will open in Photoshop if "Edit a Copy" (of original file without LR adjustments visible) is selected instead.
Phil
Date: Mon, 2 Jul 2012 11:02:08 -0600
To: maczeus@msn.com
Subject: Re: Lightroom 4.1 - problem reading 32 bit file from Photoshop HDR Pro Lightroom 4.1 - problem reading 32 bit file from Photoshop HDR Pro
created by Victoria Bampton in Photoshop Lightroom - View the full discussion
Double check that you're using a TIFF, and not a PSD file. LR will only import 32-bit TIFF or DNG.
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re: Lightroom 4.1 - problem reading 32 bit file from Photoshop HDR Pro
To unsubscribe from this thread, please visit the message page at Re: Lightroom 4.1 - problem reading 32 bit file from Photoshop HDR Pro. In the Actions box on the right, click the Stop Email Notifications link.
Start a new discussion in Photoshop Lightroom by email or at Adobe Forums
For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
CS5 probably doesn't know what to do with the file as 32-bit processing was added to ACR 7.1 for CS6.
If you set Photoshop CS5 as a secondary external editor (as well as your normal primary) then you'll force LR to render a 16-bit TIFF to pass to CS5. Or use Export with an Open in Photoshop CS5 post-processing action.
Thank you for the tips. I shall try them out in the near future!
Phil
Date: Wed, 4 Jul 2012 08:27:41 -0600
To: maczeus@msn.com
CS5 probably doesn't know what to do with the file as 32-bit processing was added to ACR 7.1 for CS6. If you set Photoshop CS5 as a secondary external editor (as well as your normal primary) then you'll force LR to render a 16-bit TIFF to pass to CS5. Or use Export with an Open in Photoshop CS5 post-processing action.
