I am trying to have two fields within the same dialog point to the same field. Structure:
The problem, is that this is being translated into ./maxResults beinf a String[] instead of a String in the JCR node. The numberfields do not handle String[] very well at all. Is this by design or could this possibly be a defect? To me, it would be intuitive for these two numberfields to both be pointing to the same JCR field, and that field's type should be String.
I have worked around this by just using separate fields (changing one to maxResults2), but I am just curious as to if this is expected behavior.
Paul
I assumed as much. I wonder if there is a better way handling this situation though, because it is definitely neither intuitive nor elegant. Maybe if there was a means to force a field to never become a multiple representation? Now I'm just getting into the realm of feature requests, which is offtopic. Thanks for the quick response, mkiti.
In fact it is possible to force a type. You can try following:
Add this to your dialog.xml (if you use xml to define dialogs, if not than you have to create the node maxResultsTypeHint manually)
<maxResultsTypeHint
jcr:primaryType="cq:Widget"
ignoreData="{Boolean}true"
name="./maxResults@TypeHint"
value="String"
xtype="hidden"/>
See also http://sling.apache.org/site/manipulating-content-the-slingpostservlet -servletspost.html
But you won't have control over which value is written. Since the parameters end up in a hash on the server-side, it could be either value. Unless you make sure they are always identical on the client-side.
However, I think I would rather redesign the dialog to not duplicate the value. Or you have one (extjs) field simply display & update the value of the other one, without actually using a form field that is submitted.
