desaturation
Jul 1, 2012 4:44 PM
Tags: #photoshop #layers #desaturation #masaks
I made a copy of a layer (a colored photo that I downloaded from Bridge) and I was messing around with the adjustment settings like desaturation.  However, when I clicked on the adjustments tab most of the selections were greyed out.  Do I need to go up to color settings and change them to fix the problem?
    Jul 1, 2012 4:56 PM   in reply to thauser79
    I do my Desaturation with an Adjustment Layer (or very selectively with the Desaturate Sponge Tool). Are your adjustments grayed out, with Adjustment Layer>Hue, Brightness, Saturation?
    If so, then what is the Color Mode?
    Good luck,
    Hunt
    Jul 1, 2012 6:47 PM   in reply to thauser79
    Is your image file 16 bit?  most tools only work with 8 bit.
    Can you save as .jpg?
    Jul 2, 2012 12:21 AM   in reply to Doug.S
    How did you arrive at that observation?
    thauser79, could you please post a screenshot with the pertinent Panels visible?
  • Noel Carboni
    Dec 23, 2006
    Jul 2, 2012 3:12 AM   in reply to thauser79
    Probably not directly related to the problem you're seeing, but take a look at the Image - Adjustments - Black and White filter and it's corresponding adjustment layer.
    -Noel
  • Pierre Courtejoie
    Jan 11, 2006
    Jul 2, 2012 6:53 AM   in reply to c.pfaffenbichler
    Hello!
    thauser79, is a layer mask targeted in the layers panel?  A screenshot would help, as would some basic info about your setup, the version of Photoshop that you are using.
    You seem to be asking a lot of basic questions, did you take some time to peruse the user guide? http://helpx.adobe.com/photoshop.html (a book is useful too, otherwise, you'll hit a lot of frustrating stops if you do not learn the basics first)
    Christoph, I think that Doug meant that most filters work only with 8bits files.
  • Noel Carboni
    Dec 23, 2006
    Jul 2, 2012 10:00 AM   in reply to thauser79
    Screenshots attached to eMails don't get into the forum.
    Please use the web interface.  http://forums.adobe.com/message/4532403#4532403
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jul 2, 2012 12:07 PM   in reply to thauser79
    No, just a separate post.
    Look at the forum using the link I posted and see for yourself.
    -Noel
    Jul 3, 2012 7:27 AM   in reply to c.pfaffenbichler
    Yes this is an overstatement by me....I meant image tools...many image and color operations only work with 8 bit images not 16 bit....but lots of other tools still work
    For example can't save a 16 bit image to .jpg (file format limitation, not a Ps limitation per se) or applying many filters
    check image bit setting: menu bar, image, mode: _____
    Jul 3, 2012 7:37 AM   in reply to Doug.S
    Can’t we just use the term »Tool« in the context of discussing Photoshop to signify what is also referred to as »Tools« in the documentation (Move Tool, Type Tools etc.)?
Incoming Links
