sarahdecarlo
Indesign CS6 just started crashing when exporting to pdf - help?
Jul 2, 2012 2:07 PM
I just got Indesign CS6 a few weeks ago and I'm using it on a new macbook pro. I had exported to pdf a few times with no problem. Today, I tried the same thing and Indesign began quitting for no apparent reason. I already tried restarting my computer. Any suggestions?
    Jul 2, 2012 2:13 PM   in reply to sarahdecarlo
    Does it just happen with one file or with all files?
    Jul 2, 2012 2:21 PM   in reply to sarahdecarlo
    The InDesign file could have become corrupt. Try saving as an IDML file and reopen, and retry:
    Jul 2, 2012 2:36 PM   in reply to sarahdecarlo
    It could be a corrupted object (image, PDF, etc.) within the InDesign file. Try an old technique: Export pages 1-6 out as PDF and see if it crashes. If it's OK, export pages 7-12, and it crashes. Now you know the problem is in pages 7-12. Then export pages 7-9 and see if crashes, etc. until you find the page where the problem is. On that page start eliminating objects and see which object it is.
    Jul 2, 2012 2:50 PM   in reply to sarahdecarlo
    If it's a bitmap image (TIFF, JPEG, PSD) open it in Photoshop and resave it, perhaps in a different format. Replace it on the page. Do the same with Illustratr if it's an AI or EPS file.
    Jul 2, 2012 9:27 PM   in reply to Steve Werner
    Hmmm...maybe I should try that. InDesign causes Acrobat to crash about half the time when I export it out as an Interactive PDF. The only thing is, it has always happened on all my ID files and it happens sporadically. If it crashes, I just do it once or twice again and it works. That would be the only reason I wouldn't think this will be my issue.
    I'll go through the process a few times and see what happens...thanks.
