I am trying to get the CFINPUT with a datefield working inside a table.
The table is inside a cfajaximport which is inside the cflayoutarea.
The code below works without the cflayoutarea.
<cfajaximport tags="CFINPUT-DATEFIELD, CFAJAXPROXY, CFINPUT-AUTOSUGGEST, CFPOD, CFTOOLTIP, CFSPRYDATASET-JSON, CFTEXTAREA, CFDIV, CFLAYOUT-TAB, CFFORM ">
<CFOUTPUT>
<cfform name="Five" ACTION="formaction.cfm" METHOD="post">
<TABLE>
<TR>
<TD>
date
</TD>
<TD><P> </P><P> </P><P> </P>
<CFINPUT TYPE="datefield" NAME="start" ><P> </P><P> </P><P> </P>
</TD>
</TR>
</TABLE>
<cfinput type="submit" name="Save" value="Save">
</CFFORM>
</CFOUTPUT>
</cfajaximport>
As soon as the cflayoutarea is inserted, the code does not run. Below is the code for the cflayoutarea.
<cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility" overflow = "auto" selected="false" title="Service" align="left">
There will be more than one date fields in the table.
The HTML, BODY and HEAD are located in the calling module.
Is there a solution?
Mike
userCold9 wrote:
<cfajaximport tags="CFINPUT-DATEFIELD, CFAJAXPROXY, CFINPUT-AUTOSUGGEST, CFPOD, CFTOOLTIP, CFSPRYDATASET-JSON, CFTEXTAREA, CFDIV, CFLAYOUT-TAB, CFFORM ">[...]
</cfajaximport>
Hi Mike,
The closing </cfajaximport> is unnecessary and can be removed.
Two issues:
1) The <cflayoutarea /> tag must be within a <cflayout /> tag.
2) The <cflayoutarea /> tag requires an end tag. (ex: either close it w/ " />" or w/ "</cflayoutarea>") Please try this:
<cflayout type="tab">
<cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility" overflow = "auto" selected="false" title="Service" align="left" source="my_content.cfm" />
</cflayout>
or
<cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility" overflow = "auto" selected="false" title="Service" align="left">my content</cflayoutarea>
</cflayout>
(depending on which way you want to include the contents)
(you could also change type="tab" to type="accordion")
Resources:
-Aaron
I tried the recommended solutions and the datefield still does not work inside a table.
Mike
Hi Mike,
Could you please post your opening cflayout tag? I wrapped your code (minus the cfajaximport, b/c it's unneeded here) w/ a cflayout tag having a height, and the datefield was then fully visible. The cflayout's height needs to be tall enough to display the datefield. Could you try this:
<cflayout type="tab" height="300">
<CFOUTPUT>
<TABLE>
<TR>
<TD>
date
</TD>
</TD>
</TR>
</TABLE>
</CFFORM>
</CFOUTPUT>
</cflayoutarea>
</cflayout>
-Aaron
Below is the cflayout tag
<cflayout type="tab" height="800" >
Mike
If I place the code in a single tab and the code is not in a module being called using the cfinclude, it works.
But if there are more than one cflayoutarea under the cflayout it does not work or if the code is placed in another module that is called, it does not work.
Mike
Hi Mike,
Could you try this?
<cflayout type="tab" height="800">
<cfinclude template="myfile.cfm" />
</cflayoutarea>
<cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility2" overflow = "auto" selected="false" title="Service 2" align="left">
Tab 2
</cflayoutarea>
</cflayout>
where myfile.cfm contains this:
<CFOUTPUT>
<TABLE>
<TR>
<TD> date </TD>
<TD><P> </P>
<P> </P>
<P> </P>
<P> </P>
<P> </P>
<P> </P></TD>
</TR>
</TABLE>
</CFFORM>
</CFOUTPUT>
I'm seeing the datefield fine. Perhaps there is some other code contributing to the issue? Could you post a full example that we can try?
-Aaron
I got the code to work with three tabs being accessed with a link in the menu on the life side of the screen. I am trying to get the next three tabs to work with the second link in the menu.
Mike
