Bridge CS6 64-bit AND 32-bit crash!
Jul 2, 2012 5:43 AM
Tags: #not #bridge #cs5.5 #crash #64-bit #crashing #navigation #cs6
I am not sure why this is but Bridge CS6 crashes in either 64-bit version or 32-bit version.  I do not have the same problem with Bridge CS5.5 which I believe is 32-bit.
I can't fathom that a 64-bit app with as much memory (more than 8GB) on my machine and a pretty decent NVidia Quaddro card would cause such issues.  I had installed the latest video drivers not that long ago (within the past 2-6 months) when I was experiencing a separate issue on a non-adobe software crash on startup.  Changing or upgrading the video driver caused the software to become responsive again and this was with a 3D software application.
If 64-bit apps are supposed to see the maximum RAM why would my 32-bit CS5.5 not crash in the following scenario? :
A top-level or sub-top level directory which is displaying results from subfolders and when I navigate to a thumbnail CS6 crashes but CS5.5 does not.
Any help would be greatly appreciated.  I think I have at least 1GB Vram
    Jul 2, 2012 8:33 AM   in reply to markerline
    With CS6 drivers are furiously being updated, so 6 months could be several out of date.
    Most crashes are from drivers.   If using Win OS look in OS Help for Event Log.
    Look in Applications for warnings, esp. Faulting Module.
    Jul 2, 2012 8:43 AM   in reply to Curt Y
    markerline, try this.  Set Bridge to run as administrator and see if that solves your problem.  Note, this does not allow you to call Bridge from Photoshop.
    I reported this bug several months ago and still no fix!!  The problem seems to be more prevalent in systems using a solid state drive.  I am totally disappointed with Adobe over this.  It worked in CS5 and does not work in CS6.
    Gerry
    Jul 2, 2012 8:51 AM   in reply to gswetsky
    gswetsky, Sounds like you are talking about the bug where crashes occur if the temp file is not on the C: drive.
    They are working on it.  Perhaps next dot update.  Believe we are still running on same as beta version.
    Jul 2, 2012 9:06 AM   in reply to Curt Y
    I seem to recall putting the temp file on the C: drive with no help, maybe I'm mistaken.
    However, it worked in CS5 and doesn't work in CS6.  Curt, this doesn't smack of rocket science to me!!  Adobe released an update to the PS infrastructure today and neither of my two bugs is fixed.
    Gerry
    Jul 2, 2012 1:09 PM   in reply to markerline
    The crashes should be in Applications section in left panel of Event Viewer.
    Jul 2, 2012 2:49 PM   in reply to markerline
    In the Event Log on the left there should be different topics.  One is labeled Applicatons and 1 General as I recall.  Look for warnings in any of the topics and expand where you see them.
    Jul 2, 2012 5:31 PM   in reply to markerline
    Try Event Viewer/Windows Logs/Application and look for an exclamation point in a red circle marked "error"......
    Gerry
    Jul 2, 2012 5:58 PM   in reply to markerline
    Well, that was a report from a crash I just caused by running Bridge at user level.  If your Bridge is crashing and you're not getting a report in Event Viewer, perhaps you should look for problems somewhere external to Adobe software.
    What are you seeing in the Application list?  Any reports at all?
    Gerry
    Jul 2, 2012 7:07 PM   in reply to markerline
    Okay, just one more question - What does Bridge do when you bring it up?  Do you get a Windows message, "This program has caused an illegal operation....." or something similar?  Apparently not, because that would write into the Admin Logs.
    Gerry
    Jul 2, 2012 7:47 PM   in reply to markerline
    In advanced preferenes if you check "use software rending" does this change anything?
    Jul 4, 2012 1:16 PM   in reply to markerline
    This discussion may help if only in a small way.....
    http://forums.adobe.com/message/4315852
    Gerry
