Has anyone else noticed this on a Mac running CS6.....
In CS5 you could move an open photo window by click and hold and move the window to wherever you wanted without Photoshop being the active app in the forground. In CS6 you can no longer do this. You first have to click the photo/window which will bring Photoshop to the forground, then you have to click and hold again to be able to move the photo to wherever you want.
Is this a bug or a feature in CS6?
If it's a new feature or the way it's suppose to work, I vote to make it like it worked in CS5....this is not progress!
Mac Pro running 10.7.4
Yes, I see the same CS6 problem on OS X 10.6.8.
On a Mac, you can normally move a window of a background app without leaving the current app by pressing Cmd as you start to manipulate it. In CS6, you have to click the background app's window to activate it, do the repositioning of the window, then reactivate the app which you shouldn't have needed to abandon just to move another app's window.
station_two wrote:
However, clicking on Photoshop window while Photoshop is in the background will bring Photoshop to the front, regardless of the modifier key you may press.
Yes, and that is a problem when you don't want Photoshop in front but simply want to move one of its windows while using the current front app.
When using OS X 10.6.8, you should be able to prevent a background app coming to the front by pressing Cmd as you move the background app's window(s). That works fine in CS5.1 but not in CS6.
I wonder whether people might have clicked on windows in the old version and not had Photoshop come to the foreground, then complained about it...
It's cases like this, where a fundamental change is made in the way an application interacts, that an option should be added that will allow the users to set the application to work each different way. Software designers might have to work a little harder to support both methods. Testers might have to work a little harder to test both methods. That's the price of making more users happy more of the time.
-Noel
No, of course nobody would complain about that.
Clicking on a window obviously should bring the window to the front. The thing that's broken with CS6 is the ability to move a background window without it coming to the front. On a Mac, every window should be movable, without activating, by pressing Cmd as you start to interact with the window. CS5.1 was OK. CS6 breaks this standard Mac usability feature.
