macdonaldshall
[Javascript] How to trim/crop an image for export
Jul 2, 2012 7:12 PM
Tags: #javascript #illustrator_cs5
Hey folks,
Got lucky with an answer the first time, thought I'd try again.  In Illustrator CS5+, I'm looping through the objects in a document, exporting each of them to an image using exportArtBoardasImage().  They need to be trimmed afterwards, as they generally have a tonne of whitespace.  Normally, I run an ImageMagick shell script (mogrify -trim).  It'd be awesome if I could reproduce this functionality from within illustrator.  I've seen people handle this by copy-and-pasting each object into a new file, sizing the artboard to that object, exporting, then closing the file.  I'd rather not do this, as it's *way* too slow.  Any other suggestions?
Cheers!
-macdonaldshall
    Jul 2, 2012 8:56 PM   in reply to macdonaldshall
    - loop thru selected objects and push the objects into an array
    - set selection to null to deselect everything
    - do your thing
    - loop thru your object's array and restore selection
    Jul 3, 2012 4:43 AM   in reply to macdonaldshall
    "I have everything selected…" It is better not to use selections where possible… If you want everything just loop pageItems? And to the OP you can loop almost anything chaning the artboard as you go… No need for ImageMagik
