userCold9
Datefield does not work with cflayoutarea
Jul 2, 2012 3:10 PM
I am trying to get the CFINPUT with a datefield working inside a table.
The table is inside a cfajaximport which is inside the cflayoutarea.
The code below works without the cflayoutarea.
<cfajaximport tags="CFINPUT-DATEFIELD, CFAJAXPROXY, CFINPUT-AUTOSUGGEST, CFPOD, CFTOOLTIP, CFSPRYDATASET-JSON, CFTEXTAREA, CFDIV, CFLAYOUT-TAB, CFFORM ">
<CFOUTPUT>
<cfform name="Five" ACTION="formaction.cfm" METHOD="post">
<TABLE>
<TR>
  <TD>
   date
  </TD>
  <TD><P> </P><P> </P><P> </P>
   <CFINPUT TYPE="datefield" NAME="start" ><P> </P><P> </P><P> </P>
  </TD>
</TR>
</TABLE>
<cfinput type="submit" name="Save" value="Save">
</CFFORM>
</CFOUTPUT>
</cfajaximport>
As soon as the cflayoutarea is inserted, the code does not run. Below is the code for the cflayoutarea.
<cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility" overflow = "auto" selected="false" title="Service" align="left">
There will be more than one date fields in the table.
The HTML, BODY and HEAD are located in the calling module.
Is there a solution?
Mike
    Jul 2, 2012 11:08 PM   in reply to userCold9
    </cfajaximport>
    Hi Mike,
    The closing </cfajaximport> is unnecessary and can be removed.
    Two issues:
    1) The <cflayoutarea /> tag must be within a <cflayout /> tag.
    2) The <cflayoutarea /> tag requires an end tag.  (ex: either close it w/ " />" or w/ "</cflayoutarea>")  Please try this:
    <cflayout type="tab">
      <cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility" overflow = "auto" selected="false" title="Service" align="left" source="my_content.cfm" />
    </cflayout>
    or
      <cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility" overflow = "auto" selected="false" title="Service" align="left">my content</cflayoutarea>
    </cflayout>
    (depending on which way you want to include the contents)
    (you could also change type="tab" to type="accordion")
    Resources:
    - cflayoutarea
    -Aaron
    Jul 3, 2012 9:56 PM   in reply to userCold9
    Hi Mike,
    Could you please post your opening cflayout tag?  I wrapped your code (minus the cfajaximport, b/c it's unneeded here) w/ a cflayout tag having a height, and the datefield was then fully visible.  The cflayout's height needs to be tall enough to display the datefield.  Could you try this:
    <cflayout type="tab" height="300">
    <CFOUTPUT>
    <TABLE>
    <TR>
      <TD>
       date
      </TD>
      </TD>
    </TR>
    </TABLE>
    </CFFORM>
    </CFOUTPUT>
    </cflayoutarea>
    </cflayout>
    -Aaron
    Jul 5, 2012 1:08 PM   in reply to userCold9
    userCold9 wrote:
    <cflayout type="tab" height="800" >
    If I place the code in a single tab and the code is not in a module being called using the cfinclude, it works.
    But if there are more than one cflayoutarea under the cflayout it does not work or if the code is placed in another module that is called, it does not work.
    Hi Mike,
    Could you try this?
    <cflayout type="tab" height="800">
        <cfinclude template="myfile.cfm" />
      </cflayoutarea>
      <cflayoutarea bindonload="false" closable="false" inithide="false" name="TANursingFacility2" overflow = "auto" selected="false" title="Service 2" align="left">
        Tab 2
      </cflayoutarea>
    </cflayout>
    where myfile.cfm contains this:
    <CFOUTPUT>
    <TABLE>
      <TR>
        <TD> date </TD>
        <TD><P> </P>
          <P> </P>
          <P> </P>
          <P> </P>
          <P> </P>
          <P> </P></TD>
      </TR>
    </TABLE>
    </CFFORM>
    </CFOUTPUT>
    I'm seeing the datefield fine.  Perhaps there is some other code contributing to the issue?  Could you post a full example that we can try?
    -Aaron
