PlanetSong
How to change the text of the drop down list items?
Jul 3, 2012 2:30 AM
The drop down list LIST includes 3 items, say, A, B, C.
I wish to change them into a, b, c.
this.resolveNode("LIST").rawValue only returns the default value of the drop down list.
but how can i identify these items and change their text seperately?
Also I'm trying to manipulate the contents of these items when a script is executed. I hope that the above identification can also help to add/remove the items.
Is there a manual that I can look up for the objects' path so that I won't be lost every time I'm doing this same location thing?
thanks!
    Jul 3, 2012 3:54 AM   in reply to PlanetSong
    You can use clearItems() and addItem() methods to change the items in the dropdown.
    There is an example here that populates the dropdown using script in the preOpen event. This looks at previous selections and changes the items in the dropdown accordingly: http://assure.ly/jcTahK.
    Hope that helps,
    Niall
    Jul 12, 2012 5:33 PM   in reply to PlanetSong
    The example above shows how you can also add a bound value using the addItem() method.
    Also have a look at this example, where we are accessing the index and bound value: http://assure.ly/fYCuQ2.
    Hope that helps,
    Niall
    Jul 13, 2012 8:36 AM   in reply to PlanetSong
    It would be easier if you could share your particular form. It is difficult to generate generic examples that cover all scenarios.
    If you can, upload your form to a file sharing site; publish it and then post the published URL here.
    Niall
