I'm running into some strange issues with some script in which another user's Mac will halt on a line that does nothing more than store a history state to the variable "actHist" while PCs run the entire script fine. We'll be testing the script an another Mac later today, but I was wondering if there are known issues with running Java based scripts on Macs vs PCs? Below is a screenshot of the problem:
I can't figure out WHY it stops on that area. I tried asigning the variable outside the else statement cause I was out of ideas, but it does the same thing regardless where I declare it. The odd part is, that same line is used elsewhere in the script without issues, it just does not seem to work in this one spot on a Mac (PC has no issues with it). Any idea why this is only a problem for the Mac and not any PCs?
Tom is right. This is a known problem and Adobe has been alerted about it. This error can also occur when trying to access a document's activeLayer.
I've used this code for troublesome lines like this and it has worked for me:
try {
doc = app.activeDocument;
} catch (e) {
$.sleep(500);
var desc = new ActionDescriptor();
desc.putEnumerated(cTID("Stte"), cTID("Stte"), cTID("RdCm"));
executeAction(cTID("Wait"), desc, DialogModes.NO);
This has not worked for others. Someone has suggested using:
try {
} catch (e) {
app.refresh();
I haven't tried this because I don't have a reproducible test case.
The above workarounds don't work for me on Windows, the only thing that has worked for me is to set the prefs to tabbed whilst the script is running.
function tabInterface(onOff) {
if(onOff == undefined) onOff=true;
var desc19 = new ActionDescriptor();
var ref8 = new ActionReference();
ref8.putProperty( charIDToTypeID('Prpr'), stringIDToTypeID('interfacePrefs') );
ref8.putEnumerated( charIDToTypeID('capp'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
desc19.putReference( charIDToTypeID('null'), ref8 );
var desc20 = new ActionDescriptor();
desc20.putBoolean( charIDToTypeID('EGst'), true );
desc20.putBoolean( stringIDToTypeID('openNewDocsAsTabs'), onOff );
desc19.putObject( charIDToTypeID('T '), stringIDToTypeID('interfacePrefs'), desc20 );
executeAction( charIDToTypeID('setd'), desc19, DialogModes.NO );
function isTabInterface(){
var ref = new ActionReference();
ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
return executeActionGet(ref).getObjectValue(stringIDToTypeID('interfacePrefs')).getBoolean(stringIDToTypeID( 'openNewDocsAsTabs'));
Interesting. I don't actually own a Mac myself, but I'll pass this along to the person(s) that have trouble with the script on Mac and see how it goes. I'll let you know if this solves the issue or not; though I'm sure it will as I do believe the one that had trouble with this the most does NOT use tabbed mode. Thanks for the help guys!
Yeah, I had them try that and it does not appear to have corrected the issue either. It still baffles me as to why it dislikes that line when the exact same line is used elsewhere in the script. The only thing I can think of is that it either doesn't like the fact that it's in an else statement, or the more likely is, it's trying to restore a history state to the wrong document. Anyway, I'll keep messing with it on my end. If anyone thinks of anything else that might be causing this, let me know!
Well, tried all the things mentioned so far and no luck. The sleep option appeared to fix it but only did for one run of the script. The script works on the first pass after a restart of the system, but then hangs again if you try to run it again, highlighting the line in the picture.
This has been tested on 3 different Macs, one of which had a fresh install of Photoshop on it before running it. All Macs had the same issue. The weirdest part is that it hangs when trying to STORE the history state rather than when it's trying to restore it.
With the sleep command, I put it in as just $.sleep(100); and also as $.sleep(1000); with the 1000 it ran through once before it stalled again the next run.
So far, this script has run perfectly on all PCs it's run on; only Macs dislike this part of the script (no other parts have issues). The only one I didn't try yet was the app.refresh(); (missed that one earlier). But, I have the feeling it's going to be the same result.
