Ian SSSS
PSE 10 Editor never opens...
Jul 1, 2012 4:43 PM
Tags: #10 #editor #pse #hangs.
Hi folks,
I've used PSE since version 1 and hardly ever a problem until v 10.
It is installed in the default locations in win7 64bit. I've installed it three times so far.
I try to start the Editor from it's exe file to aviod the Unwelcome screen.
v 10 Organiser runs perfectly well.
SInce Editor sets up ever time and looks exactly right, even loading in the picture selected in Organiser for editing, it must be something at the very final stage that is being looked for that isn't found. The first mouse click every times results in Editor freezing and displaying the Adobe error message top left, 'Adobe Photoshop Editor (Not Responding).'
I can't go back to version 9 because I can't find my CD - but that isn't the point. v 9 worked correctly on this machine.
Can anyone offer hope - please.
Thanks.
Ian.
    Jul 1, 2012 5:34 PM   in reply to Ian SSSS
    Do you have any 3rd party plugins installed?  If so, remove them.
    Ken
    Jul 2, 2012 10:44 PM   in reply to Ian SSSS
    Are you using multiple monitors?
    See if the Event Log can shed some light on the problem:  Start...Control Panel...Administrative Tools...Event Viewer.  Expand the "Windows Logs" folder in the left panel and select the "Application" log.  Look for any items with a red icon and that refer to PhotoshopElements and copy the error info into a message here.
    Ken
  • 99jon
    Jan 6, 2010
    Jul 3, 2012 6:35 AM   in reply to Ian SSSS
    Can you right-click to launch the Editor and choose “Run As Administrator” That often makes the application more stable.
    Rather than opening an image from Organizer can you check if it’s possible from the Editor.
    File à Open
    Then navigate to a folder and select a jpeg image.
  • 99jon
    Jan 6, 2010
    Jul 3, 2012 7:16 AM   in reply to Ian SSSS
    OK. I assume you are not running a network calling up information from a server. The only other thing I can suggest is running in safe mode to try and pin down or isolate the problem or raise a case directly with Adobe Support. Good luck.
    http://windows.microsoft.com/en-US/windows7/What-is-safe-mode
    Jul 3, 2012 8:49 AM   in reply to Ian SSSS
    Thanks for posting the Error Log info, but it doesn't help me much.
    I concur that contacting Adobe tech support should be your next step.  Since PSE10's Editor never worked, I would think the problem qualifies for the free support regarding installation issues....
    Ken
