Buffer performance issue with MediaPlayer object and DynamicStreamingResource
Jul 3, 2012 7:17 AM
Tags: #buffering #urlresource #dynamicstreamingresource
  Steps to reproduce:
1. Create two instances of MediaPlayerSprite.
2. On the first one, use a single URLResource. On the other, use DynamicStreamingResource.
3. When seeking to different points in the video, monitor the bufferLength property on MediaPlayer.
Expected Results:
I would expect the buffer to fill at the same rate.
Actual Results:
The buffer fills much slower when using DynamicStreamingResource as compared to URLResource.
Here is an example: http://www.cecentral.com/tmp/presenter-osmf-dsr-test/
The video on the left is a single stream, while the video on the right is a dynamic stream. As you play each video, click around the progress bar at the bottom. Take note of how long it takes for each buffer to fill.
Any ideas?
