davidhnyc
remove boarders
Jul 2, 2012 12:20 PM
Tags: #crop #reduce_file_size #crop_area #remove_boarder
I often need to remove boarder of documents that are sent to me (I am a translator so I need to print them in a size I can read), in 7.1 the was a command remove white boarders I do not want to crop a bunch of odd shaped pages
it was under reduce file size  i beleave
window 7  acrobat 10.3 Regards David
    Jul 2, 2012 12:53 PM   in reply to davidhnyc
    In AA8 the remove white margins is a check box in the crop menu. I suspect that is true in AAX also. Also, just go to the help and search for remove white space. It came up with the crop info for me. The first item was cropping empty space.
  • George Johnson
    Aug 11, 2002
    Jul 2, 2012 9:35 PM   in reply to davidhnyc
    It's still there. See the image of the Set Page Boxes dialog, which includes the Remove White Margins check box that Bill mentioned:
    http://help.adobe.com/en_US/acrobat/pro/using/WS58a04a822e3e50102bd615 109794195ff-7b8a.w.html
    Jul 3, 2012 7:45 AM   in reply to davidhnyc
    Standard is its anything like Standard on The Mac a few years ago. It is just a Basic PDF Creator no frills no extras. On the Mac when standard was available. Tha Mac's system could as much as Standard. So Adobe discontinued it. So I can see some features not beeing pro version.  There are thrre version for PC" Standard, Por, and Pro Extended. On Mac there is just one version. On Mac There is no way to make xml based PDFs in two version of PC you can.
