hide ground plane cs6 extended.
Jul 3, 2012 9:52 AM
hello.
in cs6 extended, how would i hide the ground plane.
thankk you.
phil.
    Jul 3, 2012 11:03 AM   in reply to phil 142
    Check the visibility options in the scene and environment sections of the 3D hierarchy tree. It's somewhere in there (seems those questions always pop up when I'm not on my CS6 machine and my memory is failing me so I can't verify) .
    Mylenium
  • Noel Carboni
    Dec 23, 2006
    Jul 3, 2012 11:08 AM   in reply to phil 142
    Generally speaking, you can click on a tool in the Tools Panel other than the Move Tool and the ground plane will be hidden.
    But if you want to be able to rotate, etc. without seeing the ground plane you'll have to do as Mylenium has suggested and look for a way.  I only see a way to change the color in the Preferences, not to turn it off.
    -Noel
    Jul 3, 2012 11:21 AM   in reply to phil 142
    One way is to go to to View>Show>3D Ground Plane or Ctrl (cmd)+H (toggles the view on and off) but that hides all the 3d related stuff.
