External CSS Styling Not Being Applied
Jul 3, 2012 12:08 PM
Tags: #html #actionscript #actionscript3 #external_css #parsing_css #parsing_external_css #external_html #external_css_not_loading
I've a manually created text field, newsText_tf, into which I am able to load text. The text file, writeUp1.txt, is definitely getting loaded, but the CSS styling found in "newsStyle.css" in not getting applied, or loaded at all.:mad:
I slipped in a few trace commands and supposed the CSS is getting loaded, or at least the function in which the trace code is found is getting read.:p
Anyway, here's the code:
import flash.events.Event;
import flash.net.URLLoader;
var navBanNews:URLRequest = new URLRequest("content_news/writeUp1.txt");
var newsLoader:URLLoader = new URLLoader(navBanNews);
var cssLoader:URLLoader = new URLLoader();
//Load the text file ("writeUp1.txt")
newsLoader.addEventListener(Event.COMPLETE, newsLoadCompleted);
function newsLoadCompleted(event:Event):void
          var newsLoaded:URLLoader = URLLoader(event.target);
          newsBox_mc.newsText_tf.htmlText = newsLoaded.data;
          callCss();
                    trace("Text loaded!");
//Load the CSS file ("newsStyle.css")
function callCss():void
          var newsStyleRequest:URLRequest = new URLRequest("content_news/newsStyle.css");
          cssLoader.addEventListener(Event.COMPLETE, cssLoadComplete);
          cssLoader.load(newsStyleRequest);
                    trace("CSS loaded!");
function cssLoadComplete(event:Event):void
          var newsStyle:StyleSheet = new StyleSheet();
          newsStyle.parseCSS(cssLoader.data);
          newsBox_mc.newsText_tf.styleSheet = newsStyle;
          newsBox_mc.newsText_tf.wordWrap = true;
          newsBox_mc.newsScroller.update();
                    trace("CSS load complete!");
I don't know if it means anything, but when I Test the movie, the "CSS loaded" trace is displayed first in the Output panel.
  • kglad
    Jul 21, 2002
    Jul 3, 2012 12:14 PM   in reply to Slateclean
    i don't see how newsLoadCompleted is called so none of those traces will execute.
    Jul 3, 2012 1:13 PM   in reply to Slateclean
    what kind of tags do you use?, this link show the supported tags in Flash
    http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/fla sh/text/StyleSheet.html
    Jul 3, 2012 4:45 PM   in reply to Slateclean
    I test your code and  in fact don't works.
    I only can change the link color
       a{
        color: #FF0000;
    but I can't change the color or size of the text. the color and size is defined only by  the panel control.
    I created dynamicly a textFild but the result is same
    Maybe is a bug, I tested this in Flash CS6
