Lightroom 4 RAM usage
Apr 20, 2012 8:10 PM
I'm having performance problems with Lightroom 4. I admit my PC isn't super quick, but t looks as if the RAM available is insufficient ..... looks like only a quarter of it is available...... any ideas what I should do to improve performance. It's leading to problems when exporting images - sometimes it works, sometimes it doesn't - I normally have to close Lightroom and reopen it - it normally works then. There is generally very little else open at the same time
Lightroom version: 4.0 [814577]
Operating system: Windows 7 Home Premium Edition
Version: 6.1 [7601]
Application architecture: x86
System architecture: x86
Physical processor count: 4
Processor speed: 2.3 GHz
Built-in memory: 3325.9 MB
Real memory available to Lightroom: 716.8 MB
Real memory used by Lightroom: 897.9 MB (125.2%)
Virtual memory used by Lightroom: 1073.4 MB
Memory cache size: 4.0 MB
System DPI setting: 120 DPI
Desktop composition enabled: Yes
Displays: 1) 2560x1600
    Apr 22, 2012 6:28 PM   in reply to GKN 100
    Here's mine...
    Operating system: Windows 7 Business Edition
    Version: 6.1 [7601]
    Application architecture: x64
    System architecture: x64
    Physical processor count: 2
    Processor speed: 2.5 GHz
    Built-in memory: 4047.8 MB
    Real memory available to Lightroom: 4047.8 MB
    Real memory used by Lightroom: 672.0 MB (16.6%)
    Virtual memory used by Lightroom: 715.3 MB
    Memory cache size: 457.3 MB
    System DPI setting: 96 DPI
    Desktop composition enabled: Yes..
    Displays: 1) 1280x800
    As you can see the memory usage isn't that high.  Is your windows 7 64bit?  Your architecture says x86 whereas mine says x64...  Not sure if that may help you get in the right direction or not...
    Apr 22, 2012 8:14 PM   in reply to GKN 100
    I wonder if that's why?  Here's the system requirements.
      System requirements
    Windows
    • Intel® Pentium® 4 or AMD Athlon® 64 processor
    • Microsoft® Windows Vista® with Service Pack 2 or Windows® 7 with Service Pack 1
    • 2GB of RAM
    • 1GB of available hard-disk space
    • 1024x768 display
    • DVD-ROM drive
    • Internet connection required for Internet-based services*
    Now they don't actually state 64bit OS in this however I've heard it stated that it is a requirement.  It'd be worth a call to Adobe...
    Apr 23, 2012 12:00 AM   in reply to T_Stott
    No, 32bit Win7 is fine. Think you're getting confused with the 64bit requirement for Mac.
    Jun 16, 2012 12:46 PM   in reply to GKN 100
    You should switch to using the 64-bit version of W7.
    Adobe KB states that on a 32-bit system LR can only use 2GB of memory, but I started seeing problems when LR memory usage exceeded 1GB.
    Now I'm on a 64-bit W7 and LR typically uses over 2,1 GB of memory.
    You don't have to buy a new W7 licence. One licence is good for either version as long as you don't use them on different computers simultaneously.
    If you have 3GB of memory, you also want to make sure that your swap file size is at least double the memory. And of course fixed size and unfragmented.
    But you should consider installing the maximum amount of memory the motherboard can support.
    Jun 16, 2012 1:05 PM   in reply to GKN 100
    See here what Adobe says about optimazation of Lr: http://helpx.adobe.com/lightroom/kb/optimize-performance-lightroom.htm l
