Hello everyone!
Sorry to ask such a silly question but I am really struggling with this.
I have CS4 and I have taken some videos with my OLYMPUS PEN PL-2 using the camera default settings.
When I import the videos in Premiere, they don't feet in the screen. Sometimes they are way too big or way too small and I have no idea what settings I need to chose when I start the project.
What are the settings I need to choose here?
As I do not know the footage from the Oly PEN PL-2, it might be useful if you post the detailed info from one of those files, when you run it through MediaInfo. That will dictate what Sequence Preset you should use, even if you have to choose the Desktop and Custom Preset, then adjust the parameters to fit the footage.
Good luck,
Hunt
Link is dead.
You either set up:
HD: 1280(H)x720(V) Aspect 16:9
SD: 640(H)x480(V) Aspect 4:3
as a custom preset depending of which you shot.
And install the Mjpeg code otherwise it wont work.
http://www.mainconcept.com/en/products/apps-plug-ins/codecs-conversion /motion-jpeg.html
Thank you all!!!
This is the information I got with mediainfo
Format : AVI
Format/Info : Audio Video Interleave
File size : 775 MiB
Duration : 3mn 20s
Overall bit rate : 32.5 Mbps
Mastered date : 2012-05-23 05:29:29
Writing application : OLYMPUS E-PL2
Writing library : OLYMDigital CameraOLYMPUS DIGITAL CAMERA
Video
Format : JPEG
Codec ID : MJPG
Duration : 3mn 20s
Bit rate : 31.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Compression mode : Lossy
What settings should I use here
