remove Fill & Stroke?
Jul 3, 2012 7:49 PM
Tags: #illustrator #help #windows_7 #illustrator_cs6 #fill_stroke #remove_fill #remove_stroke
Hello:        OS: Windows 7 Home 64bit
I have made a copy of a circle of which I need to remove the Fill and Stroke.
I have clicked the thumbnails, on the Tools panel, of the Fill & Stroke to set to None but this didn't remove either in my copy.
I have checked under each and every Menu option and I have checked in the F&S panel itself to no avail.
Could you please explain how I go about removing the F&S of a copy?
Oh, also ... in Illustrator is a Copy the same as a Duplicate?
Thank you for your time
    Jul 3, 2012 10:03 PM   in reply to Kar209
    Did you click on the circle to make it active? Since I don't know your experience level, I have to ask.
    Open the layer panel and the appearence panel and post screen grabs of them, plus grab the top tool bar, with the circle selected for all screen grabs.
    Jul 4, 2012 1:08 AM   in reply to Kar209
    Yeah, I mean capturing the screen so we can see whats up.
    Nothing to laugh at. We all start somewhere. Any questions feel free to ask, thats what were here for. To learn and to help others to learn. Have a good night.
    Jul 4, 2012 9:35 PM   in reply to Kar209
    I am in New York. I still get on the forums even on holidays.
    Scaling proportionally, place cursor over corner anchor and hold down shift key then drag.
    If you also hold down the alt key you can scale from the center of the object instead of the opposite corner.
    Jul 4, 2012 9:40 PM   in reply to Silkrooster
    I should correct that, place the cursor over any anchor and the shift key will scale proportionately using the opposite anchor.
    Holding shift+alt will scale from the center when placing the cursor over any anchor.
    Just want to make it clear that you don't have to use a corner anchor when scaling. Thats kind of why the shift key is required. (don't really know the true reason, but thats my guess...)
    Jul 23, 2012 12:55 AM   in reply to Kar209
    Nope, to far to NYC. I am closer to the Canadian border.
    Oct 16, 2012 5:23 PM   in reply to Kar209
    So what are the steps to Take off any stroke and fill on the text? I'm trying step 1 of http://vectips.com/tutorials/quick-tutorial-create-a-reusable-retro-ty pe-treatment/
    Oct 17, 2012 1:06 AM   in reply to StayFocused81
    You might want to take a look at this (see the video too)
    http://help.adobe.com/en_US/illustrator/cs/using/WS714a382cdf7d304e7e0 7d0100196cbc5f-6519a.html#WSDF6D5870-B06C-4e6d-9B6C-FFEB2FBDF939a
    Removing means: setting fill and stroke to "None"
