reg.cgi
Jan 13, 2009 3:46 PM
Do we just throw reg.cgi into a web server and that is it or are we suppose to do something else with it?
    Jan 14, 2009 10:43 AM   in reply to flairjax
    The ReadMe.txt file included with the "Video Phone Application source code" .zip file includes a section on installing reg.cgi. You will need to place reg.cgi (changing its name if you want) into your web server's cgi-bin location, create the SQLite3 database that it needs somewhere, and modify reg.cgi so that it knows the location of the database directory (that part is marked with the comment "CHANGE THIS"). The minimal instructions are also at the top of reg.cgi as a comment, including the schema of the SQLite3 database that you must create. The "CREATE TABLE" and "CREATE INDEX" commands can simply be copy-and-pasted directly into the SQLite3 shell.
    Up-to-date installations of Python and the sqlite3 Python module are required for this script to work without modification. Python 2.5.1 and above, and the SQLite3 module actually called "sqlite3" should work. Those are present on Mac OS X 10.5.
    Note that reg.cgi is *not* the kind of code you would deploy for a real production service. Most importantly, there's no authentication or access control of any sort. The script is a minimal illustration of a means of exchanging peerIDs.
    Jun 29, 2012 2:10 AM   in reply to Michael Thornburgh
    Michael I have the same problem. I did place the python cgi program in the cgi-bin and put the registrations.db in there too... however, having never heard of this data base I have no idea how to set it up other than using notepad and uploading it. But what if anything do we actually have to put into this .db file? I am leaving it empty because I assumed the python program would put data into it. Could this be the reason why I am getting a successful connect followed by error message ID event: idManagerError Error description: HTTP error:(mx.messaging.messages::ErrorMessage)#0 body=(null)... etc??
    Thanks.
    The audio and web cam works and it does make a connection with NetConnection, but then loses it.
    Jun 29, 2012 2:15 AM   in reply to joedart
    p.s. How does the VideoPhoneLabs program find the reg.cgi script anyway? I assume the users enter the link to the VideoPhoneLabs.html. Does that program find the Python script?
    Jun 29, 2012 2:23 AM   in reply to joedart
    ok. I added the code for Create Table and Create Index to the .db file. Still get the same errors. Instead of retyping them, here they are copied.
    Connecting to rtmfp://p2p.rtmfp.net
    NetConnection event: NetConnection.Connect.Success
    Connected, my ID: b376e91ae5f49115f352b68fc37ddfa6c365a7f9fc685e5d982e6d58f7a2d463
    Error description: HTTP error: (mx.messaging.messages::ErrorMessage)#0
      body = (null)
      clientId = "DirectHTTPChannel0"
      correlationId = "41CF1D4D-6900-3240-E3CF-378C5001BE3B"
      destination = ""
      extendedData = (null)
      faultCode = "Channel.Security.Error"
      faultDetail = "Destination: DefaultHTTP"
      faultString = "Security error accessing url"
      headers = (Object)#1
        DSStatusCode = 0
      messageId = "FD812AC6-5DC2-76C2-03DC-378C508B2964"
      rootCause = (flash.events::SecurityErrorEvent)#2
        bubbles = false
        cancelable = false
        currentTarget = (flash.net::URLLoader)#3
          bytesLoaded = 0
          bytesTotal = 0
          data = (null)
          dataFormat = "text"
        errorID = 2048
        eventPhase = 2
        target = (flash.net::URLLoader)#3
        text = "Error #2048"
        type = "securityError"
      timestamp = 0
      timeToLive = 0
    Disconnecting.
    Hanging up call
    Jun 29, 2012 8:50 AM   in reply to joedart
    here the URL to the SWF is not in the same domain as the URL to reg.cgi, so you're getting a security error from Flash Player.
    if the domains can't be the same, you will need a crossdomain.xml file on reg.cgi's web server to allow the cross-domain access.
    regarding reg.cgi and its installation: its database should not be in the cgi-bin directory, as the directory where the database is (and the database file itself) must be writable by the web server process.
    the VideoPhoneLabs source code has a spot for you to set the URL to reg.cgi according to how/where you installed the script.
    Jun 29, 2012 9:21 PM   in reply to Michael Thornburgh
    Michael
    thanks for your help. But I this is a more complicated problem than what
    domain my files are in. I looked at the code in the VideoPhoneLabs.mxml
    program and see that I have put my Domain into
    WebServiceUrl:String = "http://dartwerks.com";
    which is the web site where I am storing the html/swf/etc files
    I put the python file named reg.cgi  (with all permissions) in the
    cgi-bin folder in that same domain (which should be
    dartwerks.com/cgi-bin/reg.cgi
    VideoPhoneLabs.mxml shows it is trying to Get cgi-bin/reg.cgi in
    HttpIdManager.as.
    If something at that point is causing the problem, I am not yet seeing
    what it could be.
    Jun 29, 2012 11:19 PM   in reply to joedart
    a security error from URLLoader almost certainly means a cross-domain permission issue.
    that notwithstanding, i also get a "500 Internal Server Error" when trying to access http://dartwerks.com/cgi-bin/reg.cgi . your web server and the installation of reg.cgi isn't quite right yet.
    reg.cgi is a simple REST-y service. you can use your web browser or curl or even telnet (if you're willing to speak HTTP manually) to test it. for example:
      % curl 'http://your.domain/cgi-bin/reg.cgi?username=joedart&identity=1234'
    to set identity "joedart" to "1234", and to look that up:
      % curl 'http://your.domain/cgi-bin/reg.cgi?friends=joedart'
    once you get that working, then you can get it working with VideoPhoneLabs. i believe the WebServiceUrl must be the whole URL, such as
      WebServiceUrl:String = "http://dartwerks.com/cgi-bin/reg.cgi";
    in order to avoid a cross-domain security issue, the origin of your SWF and the web service URL must be exactly the same; that is, the scheme must be the same (both "http:" or both "https:") and the hostname must be exactly the same. if one is www.dartwerks.com and the other is dartwerks.com (or if one is an IP address or "localhost" or something), it won't work and you'll get that security violation.
    Jun 30, 2012 5:03 AM   in reply to Michael Thornburgh
    Jul 3, 2012 5:43 PM   in reply to Michael Thornburgh
    Michael
    this is concerning the cgi-bin problem.
    I contacted the technical guy at Hostmonster and he looked at the domain
    problem I am having with the errors using reg.cgi. Here is his complete
    reply:
    ". . .sqlite3 is listed as a module installed for python so, they should be able to use that for their python script . . .here's one thing to consider - I do not see xml.sax.saxutils and on line 35, they are trying to use that: import xml.sax.saxutils so, that's not a module we have by default.  Which means, if they want to be able to use that module, they'll need to install it, and in order to install a module, they will have to install python locally.  So, their best bet at this point is to install python locally using this helpdesk article:
    https://my.hostmonster.com/cgi/help/python-install
    Once they have python installed locally, they can install that module and import it.  Finally, they would need to change the interpreter of their reg.cgi script to now use the locally installed python on their account instead of the server installed version. So, they've got a bunch of work to do to get this to work. And I bet the 500 error on their script is caused by not being able to import that xml.sax.sutils module."
    This recipe above seems like a lot of work just to exchange IP addresses
    between peers. I will do it if I have to, but do you have any
    suggestions as to how else I might approach having the GETs in
    VideoPhoneLabs.swf obtain the information to be exchanged? Something
    simple is best. If I am having this much trouble, and this hosting
    company is running a common linux, then a lot of other people are going
    to hit the same wall when they try to do this no matter who is hosting
    them. My gut feeling is that this is a weakness that undermines the
    acceptance of this very nice p2p flash system. By the way, I've talked
    to several computer technical people here at the university where I work
    (I teach computing) and none of them have this specific band of
    pythonsqlite3 experience. That's worrisome. Maybe some people are
    immersed in the latest python and sqlite3 but it is by no means
    universal, even among us geeks. It's worth thinking about.
    joe dart
    Jul 4, 2012 1:10 AM   in reply to joedart
    the xml.sax.saxutils should be a standard installed module as of Python 2.0, which has been around for a *very* long time.
    the sqlite3 module was added in Python 2.5. there's no reason why a Python installation that has sqlite3 shouldn't also have xml.sax.saxutils. also, Python 2.5 has been around for a very long time (many many years).
    that being said, reg.cgi is an instructive example of how one might make a simple web service, which goes with an instructive sample application.
    use of this exact script is not required. any web service which provides an equivalent interface will be compatible with VideoPhoneLabs. i believe several folks have written compatible scripts in languages like PHP or Perl. i bet they aren't even that hard to find if you ask the Google.
    Jul 5, 2012 6:22 PM   in reply to Michael Thornburgh
    Michael
    There is something here I am missing.
    ok. At your suggestion I downloaded a php replacement for the reg.cgi
    and now I want to tell VideoPhoneLabs.mxml to get the cgi script in
    dartwerks.com's html folder instead of the /cgi-bin/ folder. so I opened
    VideoPhoneLabs in flash builder and did a search for cgi-bin since that
    is the pathway I want to change. It gave me 6 hits, all of them
    comments. Where is that pathway appended to the domain name??
    So where in the VideoPhoneLabs.mxml code do I say that I now have the
    cgi script in http://dartwerks.com/reg.php instead of in
    http://dartwerks.com/cgi-bin/reg.cgi where it was originally.
    Thanks.
    joe dart
    Jul 5, 2012 7:28 PM   in reply to Michael Thornburgh
    Michael
    whoops. I found it. In fact I found the basic problem too. I was only
    putting the domain name in the web service request. Now it is giving me
    a 500 error and that makes sense. As I have not personalized the code in
    the php script, it simply doesn't run and gives me a 500. Now maybe I
    make some progress. Thanks for all your help and patience. I read a
    number of your postings over the years. Glad I don't have your job.
    joe
