jarwulf
gradient pressure stroke
Jul 3, 2012 11:32 PM
Hi, I was wondering with cs6 whether it would finally be possible to assign gradients on stroke by  pen pressure so you can do stuff like darken lines by pressure just like a real pencil for example.
    Jul 4, 2012 1:36 AM   in reply to jarwulf
    You can apply gradients on strokes in CS6.
    You can use pressure to dynamically alter stroke size/width via brushes.
    But pressure simply won't have any effect on any gradients within Illustrator.
    Jul 4, 2012 1:04 PM   in reply to jarwulf
    No. Not in Phootshop either.
    Photoshop allows you to assign opacity to stylus pressure. This can vary the density of a color while you paint. It may give the appearance of a gradient, but it's not technically a gradient in the sence of software gradients.
    Illustrator does not have an option to assign opacity to stylus pressure.
    Jul 5, 2012 9:48 AM   in reply to jarwulf
    You can get, somewhat, the effect you're after by creating a blended gradient (assuming you also want soft edges), setting it to "Multiply" and saving it as a scatter brush. Here is the effect you can get.
    Setting the "Spacing" small and pressure controlled, lets you control color, by overlapping brush artwork that has been set to "multiply".
    I also routinely create "art" brushes with blended objects, to create soft, airbrush effects.
