OK, so this is driving me crazy.
I've got a Folio set to 2048 x 1536. I've been adding articles, the InDesign document setup of which are all 1024 x 768 (all horizontal) and with Intent: Web. So far, everything has been working as it should. I now want to have an article that is 1024 x 1000 (that is, 1000 pixels high), which the user can smooth scroll down to see the rest of the feature. However, when I try to add the article to the Folio Producer, I get the message: "Content generation error. [Error: The page size aspect ratio must match the folio aspect ratio.]"
Now, I've read on the forums here that all I need to do it make sure the smooth scrolling option is selected, but when adding the article, there is no option for Smooth Scrolling. The new article window only has Article Name, Default Format (PDF), JPEG Quality, and a tickbox for Horizontal Swipe only. There is nothing about Smooth Scrolling.
Also, when I try the import article method, where there is a Smooth Scroll option (and where I've selected the Vertical Only option), I still get the same error (the folder I was selecting had one ID5.5 document in it, with the _h suffix)
I'm certain that there's something quite simple that I'm doing wrong, but I would greatly appreciate someone telling what it is...
Marc
I've had similar experiences to this. The way I've gone around it is to change the page size to 1024x768, upload the file, then change properties to smooth scrolling, undo the page-resize (so; make it back to how it was), and update the article. For some reason that is the only way that works for me to upload smooth scrolling articles.
Thanks for the answers guys, I figured it out.
When creating the folio I had been selecting PDF as the default format. For some reason, this removes the option of smooth scrolling when adding an article to the folio. So instead, I chose the Automatic option when I created the folio and, voila! - articles can be added with smooth scrolling. There's also the option at the add artice stage to choose PDF as the format. So, you can add articles with smooth scrolling, but the default format when creating the folio needs to be set to Automatic.
Thanks again for taking the time to answer my query everyone.
Marc
