Alpha ..not working properly
Jul 3, 2012 11:35 PM
In my application i am getting alpha value from xml and i just want to put it into a movieclip.
var alp:Number=Number(findSetting("alpha", "1.0"));// from xml
                trace("bg.alpha "+alp);// getting correct value
                (bg as MovieClip).graphics.beginFill(viewerBG);
                (bg as MovieClip).graphics.drawRect(0,0, 400,250);
                (bgCopy as MovieClip).graphics.beginFill(0xffffff);
                (bgCopy as MovieClip).graphics.drawRect(0,0, 400,250);
                bg.alpha=alp;
                trace("bg.alpha1 "+bg.alpha);//getting correct value
but i have got no effect after 0.5(alpha value).
I m giving the alpha value from a Slider(o,.05,...).
in 0 alpha is getting 0,in 0.15 it looks like 0.5 alpha value and on 0.3 it is showing as it is alpha 1...
i cant understand the reason..
even i have tried (bg as MovieClip).graphics.beginFill(viewerBG,alp);working same...
please help me out..
Thanx& Regards
    Jul 4, 2012 5:27 AM   in reply to joyeta
    There are a couple of unknowns in your code.  If I replace them with knowns, then it all seems to work fine.  I would look into whatever viewerBG is and see what it is contributing in the way of an alpha value.
    Jul 4, 2012 5:48 AM   in reply to joyeta
    It works fine when I run it.  You should test it separately from what you have it molded into and maybe then you will realize what is different about it.
