P@ul@C
"Damaged" fonts in pdf file after using TouchUp Text Tool
Jul 4, 2012 3:29 AM
Tags: #acrobat_pro #indesign_printing_issues #fonts_error #indesign_save #fonts_display
Hello,
I have a question regarding an issue with lost fonts in a pdf file.
The document was created in Adobe InDesign and printed to pdf.
However, after using the "TouchUp Text Tool" in order to check the font for a certain text, several attributes of the font have been damaged in the entire pdf: all characters in "small caps" have been transformed to regular.
We've had 3 cases so far.
Does anyone know how we can prevent this from happening again?
When exporting the document to pdf, all fonts were embedded, I am not sure if this can be the cause.
Thank you in advance for any suggestions!
Paula
    Jul 4, 2012 7:31 AM   in reply to P@ul@C
    What version of Acrobat Pro?
    Jul 4, 2012 6:01 PM   in reply to P@ul@C
    Are you sure they were changed or there was just a change with use Local Fonts selected?
    Jul 5, 2012 6:25 AM   in reply to P@ul@C
    When you used the TouchUp Text tool, did you have the font you edited installed on that computer? I recall that in Acrobat 8 Professional it would sometimes let you edit a font not present but would substitute a new font without prompting you. If that's what happened to you, it may have substituted a font which did not have true small caps glyphs. I think later versions of Acrobat won't allow you to edit without having the actual font installed.
    Alternatively, it could be a bug in Acrobat 8 Professional in the handling of small caps characters.
    Jul 8, 2012 5:34 AM   in reply to Steve Werner
    Which version of AA8 are you using. It is currently at about 8.3.1 or better. If you are using 8.0.0, definitely update Acrobat to be sure it is not a bug that was fixed with a later update. Usually the text tool will warn you that you do not have the font and may give you an option to continue and change the font. I do agree that this result suggested by Steve is likely the case.
