rozymack
Lightroom 4.1 - problem reading 32 bit file from Photoshop HDR Pro
Jul 2, 2012 9:58 AM
Tags: #cs5 #mac #lightroom_4
Just watched a Julieanne Kost video about creating a 32-bit (HDR) image in LR 4.1. I tried this technique and after importing the HDR 32-bit image back into LR 4.1 (from Photoshop CS5 HDR Pro) the resultant image is blank with a warning triangle that reads "Lightroom has encountered problems reading this photo. You will not be able to make adjustments to the photo. Would anyone have an idea why this happened?
Screen shot 2012-07-02 at 12.37.07 PM.jpgThank you in advance,
Phil
iMac, OSX 10.6.8, 4 GB Ram
  • Victoria Bampton
    Apr 1, 2008
    Jul 2, 2012 10:02 AM   in reply to rozymack
    Double check that you're using a TIFF, and not a PSD file.  LR will only import 32-bit TIFF or DNG.
  • Victoria Bampton
    Apr 1, 2008
    Jul 4, 2012 7:27 AM   in reply to rozymack
    CS5 probably doesn't know what to do with the file as 32-bit processing was added to ACR 7.1 for CS6.
    If you set Photoshop CS5 as a secondary external editor (as well as your normal primary) then you'll force LR to render a 16-bit TIFF to pass to CS5.  Or use Export with an Open in Photoshop CS5 post-processing action.
