I am looking for an example of proper usage to utilze as3crypto or other tool to encypt a string and salt.
Ultimately, this is to Match an existing hash froma database that was created in php.
I have seen some incomplete attempts at demonstrating, please only send Working examples.
Did you try looking at http://code.google.com/p/as3crypto/? It has working examples there
Best Regards
Alex Liebscher
Im sorry, I deleted my encryption project. If you scan through the source code on Google docs, I'm sure you could get an idea of how it works. I believe there is a public function called encrypt, and you give that either a string or byte array.
I wish I could help more, I happen to be busy at the moment.
Best of luck,
Alex LIebscher
I was able to gte it to work but unable to get it to match the encryption used in PHP.
I create a hash made from both a password and a salt. The salt is prefixed with $2a$13$ to set the rounds used in the encryption.
I see no way to do this in this library.
Therefore I get a different result than that created in PHP.
The reason I am trying to do this is so that the hash can be recreated offline ( using this library ).
Scenario: A person signs up and creates a hash(password) within PHP as described above. Then the person uses the software which stores the hash locally. The the person attempts to access the software Offline - which requires them to recreate the Hash and if it matches - they are able to use it.
Is there a way to set the rounds of encryption with this library? Sorry if that is not the correct term.
